Whoretown - Now Interest Free
Squizz
haha that's what you get for spending all day on it :) 35 minutes FTW. Wash @ super wash. Drive around til dry. Blue polish. Wipe off. Wax. Wipe off. Window spray. Wipe off. Polish engine bay. Buff off. HEY PRESTO! Shiny car
Where is the motah? :O
nice brake lines
these things are suppose to have a motah? :rofl:
cheers. but i mite need to change them, it looks as though they already have some surface rust on there :rofl:...but they'll do for now
WARNING
Ice Cubes (big ones) have been known to sink boats Geoff! :O
BAHAHAH that is such a good line.. ahaha LINE skyrine.
this is for you marki....
hmm
excellent.
looks good.
where did u get the lines from..?
GTST ones..? dnt look like it but. was it much of a hassle.?
and see that rubber steering spacer on ur steering shaft... in the 3rd pic replace it.
http://www.nissansilvia.com/forums/index.p...howtopic=241108
get that. big difference on steering response.. u wont find one drift car in japan with a std one i have one sitting on my coffee table waiting for install.
also why is ur box in.. and is only ur rear mounts holding it in..?? from experience its easier to put an engine in with the box on at the same time..
hmm
excellent.
looks good.
bought 5m of line from my local brake shop, and 10 tube nuts, a flaring tool and a pipe bender and made them up myself.
yeh the plan is to replace all the crap that i can aceess now before the motor goes in for good.
also the box is just there so i dont have to find another place to store it. however that particular one wont be going back in :worship:
Guest
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
