Whoretown - Now Interest Free
Squizz
2rismo
ahh yes. although he has gone softcock on the ehad (staying with hydraulic setup)
i've been stirring him up so he's comnig upto qld for a session at willowbank when i get mine running :action-smiley-069:
surely ~330rwkw would get you into the low 11s range?
itd come down to tyres, and suspension setup and how well u can get out of the hole
Eug is so sexy in that lab coat
i'm wearing nothing underneath
haha hey eug its like 17 days till daftpunk!
and hat f**kin ant always still gets me ay - I had a real one running around on the back of the panel one night looked so similar!
hey! you going too? so amped for it
people have been offering me bucketloads of cash for my tickets!!
didnt work dan..
so shane what time does willowbank open
www.willowbankraceway.com.au
washing on the line.. sucks living alone... GRRR
and my hands are soft from fabric softener.
think i might go for a tug.
must suck to have to do that urself :D
Guest
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
