Aren’t they meant to show an train you new things? Douche bags scream its not in your AWA
yeh, they trained me a lil, but then the guy that is my senior took extended leave, therefore i have 2 and a half weeks of shit on my own, im the only other person who knows how to do my job sides this other guy, so there is all this guessing, and im playing with thousands of dollars of vinyls and stuff... :P
Edited by RusH_
whats happenin dano, im so fkn hungry, i feel like im about to pass out, think i mite head down to audio express this afternoon if i can to get myself a harness kit for my stereo... :D mp3'ssssss, no more 20 track cd's
then again i cant wait to get a dvd headunit, double din stylin...dvd mp3's ftw lol
not much Cheif...just looking for something to do at work...kinda been at a loose end for that past 7 hrs....
u say that like its a bad thing, im leavin in like 5 mins, hehe
Edited by RusH_
Guest
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
