Whoretown - Now Interest Free
Squizz
Thanks Terry, you dont know the name of the place and are they fairly generous with highly modded skylines .
I dont know thier name but I will take a look, they are fairly generous.
You buy a supra and I'll shit in the aircon vent. :)
Mate i dont expect you to shit in ur aircond vent. Is that an Ipswich thing. :) .
Dunno what i will do mate just keep my options open. I might by Shanes GTR when he finishes it. Thats what most people do sell there car just as they spend ten years building it.
Mate i dont expect you to shit in ur aircond vent. Is that an Ipswich thing. :P .
awww look at u, ur trying to insult me :laugh:
Hmm, heres a question for the wise. How much power can a N1 engine reliably support. I know stock RB26 is good for 300+ rwkw..
From wiki:
The water cooling channels in the block are enhanced for better flowing. The block, and internal components are also strengthened. The pistons have 1.2 mm (0.0 in) top rings, but otherwise as standard. The connecting rods are the same as standard, and the crankshaft is standard but balanced. The specifications of the camshafts were also improved for power. The N1 engine uses the same parallel twin turbocharger layout but with improved turbochargers. The N1 engine also received an upgraded oil pump and water pump, to improve the cooling and lubrication of the engine.
From wiki:
from a guess id say ~350rwkw, but with every std engine they will blow when u lean on them and when u expect longevity from them.
only 350rwkw ?? I thought many standard rb26's could pull that amount although obviously it would definately be pushing the upper limits... i was hoping that the N1 could push out 400rwkw reliably.. im looking at buying a 33GTR with an N1 engine tuned for 396rwkw.. :D any more thoughts on this ?
Its all in the tune, and how well you treat it, I dont see why it wouldnt hold that power comfortably as long as everything else is up to speed to support the power level
Mightnt be a bad idea to wind down the boost a little and make sure the tune is really good before ou thrash it around too much
only 350rwkw ?? I thought many standard rb26's could pull that amount although obviously it would definately be pushing the upper limits... i was hoping that the N1 could push out 400rwkw reliably.. im looking at buying a 33GTR with an N1 engine tuned for 396rwkw.. :P any more thoughts on this ?
Please post or PM pics and further details cause if it is the one I am thinking of dont do it
http://www.skylinesaustralia.com/forums/de...html&hl=GTR
i dont think its the one your thinking of but what one is ? I heard someone else mention a white 33 gtr with an N1 motor but wouldnt say what was wrong with it.
ive gone a bit off this one as im after more of a track car and that one looks like its been setup for drag.. and i doubt that motor will survive many track days.. too much power through stock N1. Not to mention its ugly as sin :teehee:
Guest
    • Meh, maybe the JSAI ones are FG not CF. But, given that I'm not convinced any of these look any good, it hardly matters.
    • Got them in the other day. I can confirm the r33/r34 nozzles (B8K30-AA000) are the exact same. Hope this helps anyone else that comes looking for it
    • Yeah, I should state I have no overheating issues except when it's sitting idle, with AC on (and only then) and only on VERY VERY hot days. And it stops if I turn the AC off. But I put a lot of effort into making this thing run like a regular car, I want the AC to work when I want it to work. I need no excuses as to why I should make some other thing a daily! And tbf, the thing does heat soak pretty bad, not much I can do with the exhaust running under the driver's seat, you can feel it through your shoes/pants when you step out of the car, too. Point being, aircon inside the cabin is on pretty frequently. I did think about removing heater hoses to simplify the engine bay/back of engine because I cannot imagine a scenario where I ever need a heater. Except for defogging, but doesn't AC do that, not the heater? So in this very limited situation, raising the rear could work, purely to let hot air out. I've ran the car at the track on a 35C day with the aircon on, and it doesn't overheat in that scenario so that's why I thought it was due to heat soak/heat buildup and not just general overheating under load. I had previously tried shrouding the radiator, changing my balancer to a non-underdriven one to spin the water pump more at idle too, and installing two more thermo fans on the other side of the radiator/AC condenser. (So I have 4 now, 2 pushing, 2 pulling from the rad) neither really helped in this very limited scenario. I don't know if the vents will, but visually seeing the heat steaming out of them did give me hope, not to mention the temperature of the vents was MUCH hotter than other areas of the bonnet. Enough that one of the paint guys was unsure as to whether paint would stick to it long term. I'm sure that will be fine also.
    • JustJap sell CF underskirts like that.
    • Its been a while since the last update, I've been collecting parts to overhaul the suspension - Most of the bits have arrived, theres still a few bits to come in the next few weeks and still to order I started by overhauling the ATTESA unit   I stripped it down, Cleaned the main unit and replaced all O-rings, bolts, Accumulator, Pressure Switch and painted a few bits   And done!   For anyone swapping the accumulator, a 3-inch socket makes life a hell of a lot easier   And a big pile of parts ready to go on, with more still to come over the next few weeks 😐
