morning y'all :)
My weekend was pretty good. The sil80 now idles by itself (sort of). AFM will be here mid week so gonna head out and hopefully that'll make it much nicer. Still missing 1 cyl though so gotta look into that.
AAAAAAAAAAAAANWAY!
I slept on the couch last night :D Not Bunta's fault though, I just flat out couldn't sleep, and I always fall asleep when i'm trying to watch tv lying on the couch. So I went downstairs and tried to watch tv on the couch. I remember seeing Johnny Depp do some shit with a gun and then after that nothing. So it worked!
i got bitten by a spider...i may die
:) when did that happen?
nah done it a couple of times just have to be careful about how much pressue and where you aim it. Admittedly all the cars I have done it on are pre 1990 and all bar one were carby :)
Hi anna :D
Ohh i was switchin between that movie and another one on Chn 9.
nah done it a couple of times just have to be careful about how much pressue and where you aim it. Admittedly all the cars I have done it on are pre 1990 and all bar one were carby :P
Hi anna :D
I should have got you to do mine :) I ended up doing it by hand, still looked rubbish thou :)
Hi anna :)
Morning
Karchers are great, you can get in little places, espcially good if you give it a good coat of undiluted degreaser through a pressure can first :)
Yeh I did see that for a sec, Sean Connery was on the phone when some guy was being all strapped into the electric chair :D
yeah i get some stuff from the truck stop my old man works at is really good works well.
I even have the two different wands for it (fan and point).
josh we could of painted a couple of things in the enginebay as we have been putting same colour blue down on door jams and then adding clear. for the shiney finish.
Ah well, next car :D
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
