Bah I can't even log into SAUQLD...f**kers!
The wreckers was awesome today, found a nice EXA there to get some bits off...also got myself an as-new injector loom for the paltry sum of $5. May go back again tomorrow for more fossicking fun!!!
Woot, Gotta love good old wreckers bargins!! :)
I love how polite Becks is. Going by how polite she seems on the forums I imagine that she must be very posh. I bet that she's drinking a cup of tea right now. With a saucer underneath it. At a table. With a tablecloth on it.
Beck, you are awesome. You should come over and tell me how I'm ironing my shirts all wrong.
That is the funniest thing I have read all week!! bahahaha
are you the girl from the movie "hard candy" and if so, where can I get one of those red hoodies that will fit me as a guy. they seem to make them for girls but I don't want a girl's hoodie. If you're not then nevermind.
oh hey, of you're from like "the land" what sort of R.M Williams boots should I buy. I can't decide whether I should buy brown ones or black ones or what sort. and since you know how to castrate cattle then you should also know about boots and how to cook steak.
I didn't go to a country school, and righ tnow I am dinking a cup of tea. With a saucer underneath it. At a table with a tablecloth on it. I am dissapointed that you are not posh.
I wear ironed clothing for the same reason I choose to not live in abject squalor. Because I choose to maintain a standard.
Followed closely by the above...
HA!
It's great that you eat meat. I was having a conversation with one of my friends the other day about eating meat and that in order to eat meat you should have to go out to the Abbotoir (sic) and press the button to kill a cow yourself. Just once. Because then you could have no illusions about where meat actually comes from.
Are you flirting with me? I can't tell because I'm basically a high functioning Aspergers.
Genuine ROFL...
Wreckers = Insanely hot today....was once again outweighed by the bargains I scored :)
TPS + drivers side vent + random trim parts + 2 x 260cc redtop injectors (RB20 type) for $60
They just cant resist the hypnotic effects of your sexchi body!
That is disgusting. I can't belive that you would drink that.
Inedible means that you can't eat it. Nor would you want to.
Well you know us refined, pinkies up people dont slurp it like you young uncultured ruffians.
Guest
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
