Because SAU people can't be considered mates :dry:
Kinda disappoint...
They are. Don't get me wrong
I can kinda understand as far as which direction the club is going, but in my mind asking as its forward that's all the matters
Is it though? That's where the question lies.
Ok I must of got you wrong, cause I sure as hell class alot of the people I've met through SAU as at a minimum of aquaintances and the select few that talk to me on the reg I'd class as mates, he'll most of the TSO boys I consider great mates of mine :wub:
*weather that feeling is mutual I have no idea lol
Oh hell yeah! Made some great mates through the club as well! But over the past few months, I haven't had a chance to scratch myself, let alone meet with other mates. My best friend is getting married in September and I'm meant to be her maid of honour. Been that wrapped in club stuff that I haven't been able to help her with that. On top of the fact that I've been putting hours in to the club which has been detrimental to my productivity at work and has cost me financially and emotionally.
am...
I your mate???
MATE!!!!
I can understand this Tony, especially with long work hours and kids to look after. Hell, I don't even have kids (unless you count dogs).
This is the sole reason for me not wanting to contribute more to the club, I barely have the time to sort my own life out most days anyways.
Having said that I do want to get to more club dinners, meetings etc, Just haven't had time.
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
