Sold more VW bits, now wash and detail The Wife's Beetle. It must be clean your wife's car day :P
Then go get the Ute, load it up with more VW stuff. Park that in my garage while the skyline rots outside at my folks place for a night :(
......then BEER!, glorious beer.
Guest
