It's a random thread for talking shite. Very little useful content more like an ongoing conversation.
Just give nick shite about the LS1 and were all good. :)
Get faurked maxima owner :P
How bout u introduce yourself mate I.e name, what car you have and I believe Cap will fill u in on the rest :)
Yep well ahead of you Ant man, there's not alot of questions that need explaining but all of us whores welcome you :)
*except for Luke, Luke hates you :devil:
Only your R33 could offer you more love... Are you north or south side?
northside :)
i would love to meet more people around my area, i know there is a white 32 and a black 33 gtr like 1km from my house
Well that's good, Half love... The most love a man can hope for lol
half from you guys and the rest from my skyline :) full loved :)
spun bearings.
seized motor.
dirty 30 coversion.
ran out of money.
problems with manifolds.
started july last year.
just starting to get close to finishing now.
dirty 30 conversion?
what is wrong with the manifold?
dirty 30 is a term given to when you use an rb30 bottom end from a vl or older skyline, put a twin cam head(25/26) on it.
The manifold problem, was that for the size turbo I chose, the cheaper stuff didnt fit.
turbo fouled and bonnet didnt even come close to closing.
so dirty 30... make more power or? not really
that sucks about the mani. do is supra style.... cut your bonnet up with a nice big dirty hole and pod straight on the turbo hahaha :no:
Edited by cowdy
more torque, nicer to drive around town.
and giant turbo, more powah!
extra capacity helps spool the turbo.
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
