eeewwwww, or literally?
Noice ;)
FnF night was good. Downshifted about a million times on the way home, like a baws
Yeah bro! Same. Had a good run with Mike. We's had funnnn ;)
If you know what I mean.
Yes, could u imagine if this was my daily driver how f**ked off you'd be!? It's been up there since last monday
Normal gearboxes aren't as fuarked as yours is/.
No, I just really wanted the 'danger to manifold' light to come on
Same really.
Yep that'll do it :no:
.... It's ok it's only an rb20 they're cheap
RB25 dude. Get it right. None of his cars have a 20 in them.
Wedge - RB25
Leopard - VG30
Pinny - RB30
GET IT F*&()(ING RIGHT!
</3 you bro
25 b*tch! But they are also cheap :P
You sl*t! I was promised wristies and a lappy and got neither, and instead you play with Mike :(. Lucky I have Chants
*gumble grumble bitch bitch* Tis going to be 1 cranky bitch today. Faaarkn kids and truckie
Hug?
Wedge - RB25
Leopard - VG30
Pinny - RB30
</3 you bro
OK I forgive you. Big <3
Ok ok, I thought the wedge had a 20.... It had a 20 from factory right?
20 Redtop POS from factory. Blew that up and put a 30 in it. Then blew that up and now has a 25 in it. 26 next?
im out.
had a nice hot shower.
am all relaxed and shiz.
and ants, I come her for the pie.
ma man :thumbsup:
You have me curious? Do I dare google it?
only@ ur own risk (should I say @ tony's risk :D )
You not doin it right Cowdy.
lol.....he'l get there
twaz my situation many years back and not funny - had to bus it for 6+ months then another 6 months bcause was a hoon (40k's above limit = bye bye license)
yes, hug?
You sl*t! I was promised wristies and a lappy and got neither, and instead you play with Mike :(. Lucky I have ChantsHug?OK I forgive you. Big <320 Redtop POS from factory. Blew that up and put a 30 in it. Then blew that up and now has a 25 in it. 26 next?
VQ35!
Vh45 next?
Close...
vk56 ftmfw.
Closer....
VQ35!!
Yes. I think I'll take those hugs actually. Arrgh. Cranky camper :/ I got coffee to make up for said buzz loss this morning, waited about 10 minutes for my so so cofee only to go to hop in the car and have my belt break. FML!
Guest
    • I've sent JaseR33 a private message in the hope he gets an email and contacts you
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
