Better pushrods is an oxymoron.
For tyres I would see what sort of money you can get Federal EVOs for. Or just use the 595s and get them hot, Noel used them back in the day and they performed well after a large burnout! Also Theo Woolett ran a 9 on them in his GTR so they cant be all bad!
But in all seriousness 90/10 shocks is what you really need. When I first upgraded the turbo in my old 32 I had no traction at all, if I went to pass someone on the highway it would put on a smoke show! But i set up my subframe bushed for squat and got the shockies set up to keep the weight down over the rear and the problem was solved.
In fact I wager that even with bigger, better street tyres you wont get much of a result until the suspension is addressed
nik, some sound advice here.
you will probably find you get more traction if you swap out your coil overs and put your standard struts in.
I don't have standard struts :(, car came with coilovers.
*first world problems jpeg
ur skatin everywhere :woot:
Yer it's slippery as hitters hair style, but that gives you an idea of what I'm dealing with (which I'm sure any guys with big power can relate to [even if mine dosent have big power the stall makes it feel like it dows])
ROFLcoptor
:/ Seriously bro. Buy a Maxima.
LOL (and it continues)
Yer I'm regretting not going the 90/10s like I wanted to. Then everyone was like "no no get coilovers and just soften them up youll hate 90/10s" :dry:
coilovers are too hard for ya - as Luke mentioned struts TWTGO
Edited by Ants
Lawl. Take your car against the abomination at drags :P I know that you said you couldn't be there, but I can drive her :P
I could do that... or I could take my car with me and try it out on the lovely new range they just finished on my way to where I am going... I am yet to see the abomination and I am looking forward to it.
Guest
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
