I just love it when people budget with their tax refund. Lucky those measures of simplifying ITRs are in limbo FTM. Or you would only be getting $500 back.
Not really budget, more just work out how much money I can play with. Without dipping into the savings too much
I got an 18k bill once. That was pretty upsetting lol
Ive had 10.5k......that was not good, and my own stupid fault
Why are the cops out in force tonight?
school holidays? more moneys
I got 7.5k back one year, ever since has been more like 1500. not that I'm complaining. its better then a bill( how do you get a bill on salary, Bunts?
1500 is my general number :) nistune here I come. Hopefully
lol, so thats what that button does
Ewww more social media
Need more deductions man.
^this
Hating what a former President has done to us right now. So f88kinh pissed off!
former who?
Do it.
Would love to but I will refrain from doing so. It also happens to be a very expensive bottle and I have work tomorrow!
I'm assuming an a Qld SAU president? So.........what did he/she do to get your knickers in a twist?
You are not accounting for a those offshore investment accounts that he has generating 60k worth of interest income p.a. from illicit activities :P
Guest
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
