So the cops just came to work and asked my why my car was on the side of the road....
Hmm let me see, because it f**king broke down and I had to get to work!? Ya dumb bastards, I have no intention of leaving it they're to rot!
f**king morons
Maybe, "see to it that the car is removed promptly"
.... Yes officer flamin mongrel knuckle
Should of told them 'to see to it that my car doesn't get broken into instead' I can think a billions better things for them to do!
Wow, they bothered coming to your work for that? My skyline broke and was sitting on the side of a busy street where it was a tight squeeze to get past. Was there all day whilst i was working and i didnt hear anything
I know! I was waiting to get fined for it. It's on a f**king back road 5ks out of town on no danger to anyone
When I had the black c210 I parked it the front of a unit complex in woodridge(yeah, I know) and within 2hrs of it being parked I got a call from the popo making sure it wasnt stolen amd informed me that its not a great area and that I shouldnt park It there if I cared about it... some cops are nice. Not many though
Went passed workshop today. Much happier I must say :yes:
1. I received the insurance proceeds in full
2. engine is finally starting too look like a complete engine (hot side almost completed) and looks awesome with the Mines dump pipes (no pics) sorry.
Why you no get pics, I say this because I would have sex with my dump pipes but no one ever gets to see them
Edited by Bunta
Guest
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
