Cognac is good after a really nice meal (usually dinner). But whisky........you can drink that all day and even on the golf course.
Love it!
not all whiskey. You can never drink Bourbon. Because it's shit.
And it's a timing jitter. .. the crank trigger fixes it :P
Sorry I got all my mumbo jumbo mixed up :P
So what they said was that it is an issue that you will see more frequently as the cars are getting old.
The first thing they said was that they are using Ross crank trigger kit to resolve it - big $$$$ there
The second thing they said was that as the cars are aging dirt, oil, dust and other crap gets in the CAS and causes issues with resolution
They advised that you should either take the CAS apart and give a thorough clean or just buy a new one (which costs something like $500 new from Nissarse)
They mentioned that it is an issue that happens in 1/5 cars (makes sense if people get new CAS or get them cleaned)
They advised that Haltech Platinum Pro ECU has no issues with Nissan's optical CAS (selling pitch I think)
That is all I can recollect from my discussions with them (except for the addtional features Haltech has over Apexi PFC)
Interesting. I am almost tempted to try haltech just to save the pain of going to a crank trigger!
That's predominantly why I have gone with Haltech mate and I will put it to the test.
Don't think I can make it to drag day. Rego is due :/ gonna have to pull all finds togeather and use them feet for the next few days
The grandparents are gonna help me out which what I can't come up with thank god
Zac I can pay for your fare. But just this once.
I will eagerly await your results. See if it is possible to get a cas signal trace when it is tuned.
Me three. After speaking to M.Spry he mentioned I should by new z32 air flow meters.
Nah it's not that :P it's fuel hahah. I'm going to talk to my grandparents about making my repayment a little lower so I can have a little extra to save :D
But thanks ants :) means alot
No worries mate.
Guest
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
