Its a good family to be apart of. A completely fu*ked up one but defiantly a good one
apart of..............................defiantly..............................????????
you meant to say.......................... to be a part of................................................and definitely
However Cook is still in and he is farking amazing
I want to have his babies
PS i am tired, stayed up far too late watching Agars innings
I went to bed at the lunch break. Sort of wishing I stayed up to watch the rest of the innings but just couldn't manage it.
Spend a day with me and I will teach you, and you can teach me how to repair banged up cars ;)
Speaking of people doing stuff, I have all I require to do my tax now, I will send you a PM some time about it.
Fuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu, Finished my reporting for next years compliance plan, Now have to do the reporting for a member of my team who is sick. So much spread sheeting today, I went to uni to avoid having to do this shit lol
just realized one air filter has gone inside the engine.
where do i find these from
i only need actual air filter.
http://www.ebay.com.au/itm/Trust-Greddy-Airinx-Filter-Kit-Nissan-Skyline-R32-R33-R34-GTR-RB26-DETT-/120946097324?pt=AU_Car_Parts_Accessories&hash=item1c28f2fcac&_uhb=1
ebay has lot of trust airinx kits.. but not actual filters.
are they generic filters ?..
basically one of these - may be i might replace both to be sure..
Edited by maclarenf1
from here mate.
http://www.perfectrun.jp/src/detail.php?pid=30001&pname=GRACER%20AIRINX%20B%20Type&maker=TRUST&maker_id=30&result_mode=pmk
WTF?
gone inside the engine? and not caused problems?
this might actually be what you want as I'm also going to order one
http://www.rhdjapan.com/trust-greddy-airinx-b-type-air-intake-replacement-filters-m-type-169mm-51697
Yes Thats it..
now is there a place in brisbane where you can just get it off the shelf.. if i need to get it from Japland, will get Mr Jess Streeter to send it.
WTF?
well, it was half sucked in and half still there... but the other one looks to be in perfect nic... so a bit worried about that..
so far don't seem to have any issues or wired sounds or anything...
Yes Thats it..
most likely japland bro. I'm going to order two new ones, so I can order three and you pay me lots of kesh after :D
Epic intake sucked in the filter? How though?
don't think it did Tony. By the looks of things at worse it would have gone into the front of the tubrine housing as it does not have any air flow meters (I see HKS air flow meter less adapters which Im also after ;) )
Car runs HKS F-Con - so bar sensor - no air flow meters involved.
Guest
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
