Yeh a clicky here and a clicky there (30 seconds later) did fark all :no:
who wants to wait 5 mins between shots.... :thumbsup:
It was particularly bad when the nurses would come and give you some notice that they were coming to change the bed sheets so click click 5 minutes later they turn up and roll you over to change the sheet and you just want to rip the farking heads of cause it hurts so farking much. After about the 4th or 5th day and the pain is starting to subside its not so bad. And this was when i was only 12 or 13.
Not very I wouldn't think...plenty of after market suppliers plus wrecker yards :thumbsup:
The seller may even have the wing...he may have just taken it off for a different look
Off to lunch now...BBL
would like a genuine one if i could get one.
Dont mind the type 2 as its not to big.
One other thing that it will get is a carbon bonnet....really like the eastbear one
Guy on teh forums here is called MrVSpec...he works at Custom Carbon :no:
His car is awesome BTW...lots of nice carbon bits here and there :thumbsup:
I just know it is a good car and has been recently rebuilt...I am actually trying to help you but *shrugs shoulders*
Its all good man, i appreciate the help. The thing that worries me about it is those god damn tri spokes......lol. Do you know if the minor accident damage has been repaired?
The reason I asked about 4ZzZ was it reminds me of JJJ before they went all political correctness and generally began to suck big time, so it's been around a long time, must be the new location I'm working in (Kenmore) because I've never tuned it in before.
There was no actual accident ie panel damage if thats what you mean... :spank:
Those tri-spokes are worth quite a bit...but like paint, can be changed very easily :P
Guest
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
