Peeps been reading up about electric exhaust cut outs... I would love a pair on my car.
Basically a y pipe off the headers with an electric valve on it, closed goes through your normal system....
Open and it's Straight of the headers :banana:
So will you.have it tuned fir open pipe, or full exhaust? Dual maps would be required otherwise
Yer was thinking this before, I won't actually get them as its fuarken stupid and impractical but would be cool.
I'd imagine tune it with them open, so it'd just run rich with it closed? Right? :/
Huh? What ecu does he have then?
I was more saying there's two types of "can't". There's no you can't - because it's difficult. Then there's you can't - because it's genuinely impossible.
I have no idea what ecu he's running as that would require me taking more than a passing interest in the slow noise boat, which I simply don't have.
How about, shutup can't
So we have roadworthy station inspectors here
And zeke told me that there was a skyline stolen from a car yard down the road (had seen it there many a time)
So I'm pretty sure I'm gonna leave my car in the workshop at night for the next few weeks.
Might have to go for a visit to chris
Ok, I was going to say if you wanted launch type antilag, I know of a way, but for shift type antilag, I would suggest just using a ign cut attatched to the clutch over say...4k rpm. As you already has teh antilag, I will close my word hole
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
