Apparently it works alright on the rbs. If it blows the bottom end, sure I can find a 30 bottom end for a case of beer.
My first R32 was a GTS with the manifold, turbo, injectors and 'cooler from a blown GTSt added to the stock motor after I lost my licence and had 3 months to kill.
Try a td06 on 2 litres and then come see me.
Why would I do somthing silly line that
A case of beer. .. and the 5000 dollar build to make it all work!
All the lags.
-5s I beleive.
brand new -5's indeed.
-5s are pretty close to too lazy on a 2.6 for my liking.
Bunta's right. -5 on 2.6ltr is pretty laggy in comparison to -9s (GTSS) or -7s (R34 N1s) and are more suitable for 2.8lt built engine.
But we will see what it delivers first before I start ranting on about how useless they are on the street.
Been there done that! Surge ported 3076 sounded amazing too and kicked hard. .. but the lag was :(
That's why I went 6 gears instead of 5.
And added AVCS (Subaru vtec yo).
And went E85.
And v-mount.
And Twinscroll...
Granted a normal sized turbo from the start probably would have been far easier, but where's the fun in that???
We could do this... Or have the ark running by then and take it down. Hence why I said take it off the road.
We could do this.
You never said what you thought of Adelaide wines...
How.
Does.
She.
Put.
Up.
With.
You?
I wonder the same thing sometimes
I'm getting mine done custom. ;). Only way to be. :)
I want a custom one for the Ark.
agreed. Mine are some hybrid thing based on 2510s and high flowed. They are good but can't recommend them to others as who know what the part numbers are lol
Yeah, I miss my old GTR number 1 which had GT-SS.
I almost put 2510s in it but sold it off 2 weeks before I'd killed 2 turbos after bit of faffing about and in the end a pair of GT-SS went in and was loving life.
Bunta. I purchased a 24 tooth cam disc item number DSM24t to try and mitigate some of the timing jitters when they raise their ugly head in the future.
Where from? To be honest, with your engine being brand new, I do think that is a solution that will work for you, and even if it doesnt at least Sean will know what to look for and be able to tell you if it didn't fix the issue
Yeah, they are pretty much spot on in terms of useable power
http://triggerdisc.com/
Sean seemed rather relieved after I told him that I swapped from PFC to Haltech.
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
