Current Squizz hasn't slept for 3 days and is grumpier than normal, thus doing his very, very best to preserve the sensitivities of the current tampon-inserting Whoretown crowd by not kicking sand into their vaginas.
lol
At Bundamba Poo Farm.....
Fun times!
So when you getting back into a skyline timmy?
Hardly, but if you've spent the time and money building your car why run inconsistent fuel and risk your motor when there's a proven and stable solution available?
this is understandable for a built engine that sees a hard time.
but when it comes to daily duties, 95 or higher from the local servo.
And we appreciate your sensitivity, and we shall as a group do our best not to kick sand into any of your many female openings... If I didn't know better I'd say u were a vegetarian
#ifyouknowwhatimean #southpark
This amounts to "I am rubber, you are glue". I thought you had potential.
Good morning all!
Mr Antz,
I have a question for you regarding the new novated leasing rules. I am considering entering a novated lease, the car is for 100% private use, not one of those deals where I use it for work and home. Do the new rules effect this type of lease? Cheers, Andrew
  • The proposed changes in relation to car FBT take effect to all new contracts entered into after the 16.07.13 - so you would fit that description
  • The changes basically mean that the more concessional FBT method (the statutory method) has been binned and more FBT revenue will be captured
  • However, the start date of the new rules is quiet conflicting as the statutory formula can still be used for the remainder of the 2014 FBT year (1 Apr 13 – 31 Mar 14). Subsequent to that date only the operating cost can be used.
  • This means the employer must use the operating cost method when calculating the FBT payable on the car they provide to you and involves keeping track of all costs of operating the car for the FBT year
  • There is much uncertainty regarding this pronouncement considering the amount of lobbying from large car manufacturers and the private sector
  • There is even more uncertainty as the coalition have indicated they will oppose this measure and remove it if elected into Government
  • In your case Andrew, I strongly recommend you enquire from your employer what policy they are going to adopt regarding the proposed changes. If they are unclear, advise them that you can still use the statutory method until the next FBT year.
  • Please remember that, in order to make this arrangement effective that precise details of the arrangement between you and your employer needs to be governed by a written salary packaging policy and should include the following:
  • The total cost of employment (TCE) which includes cash salary, superannuation contributions, the cost of the benefits provided and FBT payable by the employer) should not exceed a certain remuneration amount
  • GST credits are added back to the employers package (because they can claim it back if they are GST registered and I highly doubt they are not GST registered)
  • GST is payable on any contributions you make to the package i.e. if you pay for fuel.
  • I do hope all of the above makes sense to you, if not just let me know.
Guest
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
