drooling over taylor?
So wrong. Can you just imagine the song that shed write?
Just a dopey boy
Loving a f**ked up toy
Took the abomination
And did skids everywhere....
And they went on and on and on and on.
Sung to Journey's Don't Stop Believing.
Can someone please tell me that it was well-composed? I thought that it was a masterpiece.
it was well composed.
srsly, wasnt too bad.
as soon as I read the on and on part, thought journey.
Ok Whores, opinions required
Looking at a soft roader type rig, it is to replace the Mazda, so 4cyl is preferred, we need it to be able to take us camping and to take Annas make up gear on location, so a little bit of off roading is required ie if its a crappy dirt road or crossing a horse paddock it needs to be able to do it mainly to save Anna haling all her shit around on foot like she has to now. The car will still spend 90% of its time on the road around town too.
I narrowed it down to a Forrester 2008 -2012 or a 4cyl Grand Vitara in the same years.
In terms of engines, external size and equipment they are more or less equal. Same price pretty much
The Forester is the more car like apparently, is 100kg lighter. The Low range is only 1.2 ish so not very low at all. Does have an electronic diff lock as well which is handy. Also comes with roof rails (swags can go up there) and a 450L/1600L load area. 220mm of clearance.
The Grand Vitara is more truck like, has a proper low range at 1.9, a faux ladder frame chassis, also has a electronic locker and hill decent assist. It has a smaller load area, 380L/758L and no roof rails. 200mm of clearance.
What say the whores?
if you go the subie, make sure to keep up the servicing with the upper engine cleaner.
you probably have, but have you considered xtrail or awd dualis?
dualis might be a little soft for what you want, but does have electric centre lock.
more car type.
just food for thought.
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
