go the subie.
for the amount of off roading youre looking at, its bot worth giving up the car feeling.
just keep up those upper engine cleans.
I am almost there with you. However people we go camping with have a Prado, a Vitara and a Navara. The Suzuki stands a better chance of being able to go wherever they go, which would be nice.
Will have to go drive both and see where that leaves us.
24 hour test drive through the mountains?
24 hour trial as a grocery getter would be better! Don't need it to be a good mountain runner, just needs to be a solid car like the 3 is with added 4x4
Mr Scott, Mr Tony, Mr Bunta, Mr Luke.... *sup nod*
Morning
Morning
What you say is true. Those 24 hour test drives must be awesome!
So, I've done some research into sprint days. Categories are as follows: 4 cyl, 6 cyl, 8 cyl and AWD. Turbo/super charged vehicles move up on category therefore Mike and Nick will be in the same category for sprints.
So will Martin
And Matt
And Zeke
And everyone else who wants to rip apart the Abomination
Nice. So you're going for a brand new one?
With the Forrester no, the new model has a range of limitations that put it out of the running, So for Forester we would be looking at a 2012 to 2010, Vitara will likely be new, especially if I lease, Remserv was offering very good deals on Vitara for QLD government employees as in 4k below retail good
So will Martin
And Matt
And Zeke
If i run RWD can I beat up on the A-Bomb too?
With the new vitara, what are servicing costs like in order to maintain warranty?
With RWD, I believe so. If you can demonstrate that the car will only be running in RWD mode without the ability to switch on track, I don't see it being an issue.
Ants should join in as well. I would love to see a stock standard NA R33 beat his ass around QR. Although, I'm pretty sure that Martin will run the Pinny and flog him.
So will Martin
And Matt
And Zeke
Nick is too much of a skirt to enter so we won't be able to :(
If i lease, the cost of servicing is built in. but its around 300 bucks per 10,000km
Guest
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
