If i lease, the cost of servicing is built in. but its around 300 bucks per 10,000km
Ok that makes sense. Some leases don't offer that. That's not bad either. Some places have 5k km for the first 3 and then 7k and then 10k. Just crazy!
Yeah, well there is a 1000km one but it is free.
Subes are even better only every 12500km!
12.5 ks actually works really well. Only problem is the incredibly dirty head they givee ;)
yeah, I dont love the idea of a boxer but apparently they are ok, they never seem to be able to match the claimed fuel consumption though
Flog the bejeebus out of it in your 24 hour test and then go back and say it used xl/100km instead of your yl/100km that you claim. Not interested. And as you walk away, they should just drop the price :D
I imagine they will just say 'that's because you flogged the hell out of it '
So, I've done some research into sprint days. Categories are as follows: 4 cyl, 6 cyl, 8 cyl and AWD. Turbo/super charged vehicles move up on category therefore Mike and Nick will be in the same category for sprints.
what you really want is put Acrapbomb in the middle of this..
What's the issue?
its a two prong issue actually (GST and CGT) an - a contract of sale fell through (thanks to dodgy buyers) was to be going a concern but now the client may be strata titling
1. what are the CGT implications
2. what are the GST implications
3. how are the deposits / installments / received from previous potential purchaser treated i.e. subject to CGT - what CGT event (I think A1 but is deferred if satisfy continuum of events for two years)
4. are the legal costs incurred so far to date to be capitalised (may depend on CGT treatment of forfeited deposits)
5. how will the deposits be recognised for accounting purposes
there you go mate. I will leave it with you. Property in question has a estimated mv of $7M
Guest
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
    • There are guys on Facebook under, Infiniti Owners Australia   https://www.facebook.com/share/g/1Z3RbPqx4k/?mibextid=wwXIfr What Whp are you after and I can help, and join this Q group in the states. https://www.facebook.com/share/g/19A59cN3JR/?mibextid=wwXIfr
    • Does any of you guys have instagram pages for your builds? Keen to see some Aussie builds. I still can't figure out how to post photos in here.
