Mr Ants, here is a well interesting article on the problem I experience and had discussions with you about. His before CAS signal plot looks just like mine! http://www.skylinesaustralia.com/forums/topic/384932-new-rb-parts-with-results/
Also may have solved my computer issue for a lot cheaper than I thought so it may get done earlier now!
that's positive news Bunts
not much except that he endorses it and is well experienced in tuning it.
Cool I thought as much, he recommends Wolf but only because he can personally get them the cheapest or somthing along those lines, he told me that any of the top teir ECUs are fine by him
In regard to that article I dont actually expect you to have the same issues because all your timing gear is newer, but it will be a really interesting tune to watch in that regard
Ya it is, Just tracking down info on the ECU now but it seems all good.
Edited by Bunta
Yeah, also I know Paullie runs a Ross crank trigger kit. He also makes 470rwkw with -5s so I can understand why he has it.
Yeah that will be the main difference, I just cant justify paying the money for the Ross kit, and Dan recently had issues with several Ross balancer's apparently the cranks were full of tiny little cracks from a dodgy balancer.
Hay guys just stop in to say hello =)
Hello
in the event those jitters crock up I will install that trigger disc. Hopefully that will help.
Guest
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • lol no cats running str pipes … might put the high flow back on but I suspect it might effect my ignition timing a bit.
    • That looks a bit like yellowing to me. If the rear bar was looking like that from rich idle, I'd ask the question, do you have a catalytic converter fitted, and fully working?
    • Oh yeah gets really bad down here. I’ll have to upgrade the heater and wind screen wipers as well for optimal performance.
