Glorious day today for my Birthday
Happy Birthday Ants
Speaking of research my last project was links. I got it in the car. Found the set up file. Went to configure it and see if it would fire up....flat battery :(
That sucks wang.
What do u plan to use the car for?
Few options out there, but the only real ones I'd look at for high output handling capabilities vs dollars invested are C4, Th400 and power glides.
I've heard some guys in the states doing fantastic things with the re4r03a (300zx auto) but its pricey, I believe tony rigollis mob builds them over here same deal with the old school 3 speed jatco boxes which the name illudes me of but I've seen people pull decent numbers from them as we'll.
T350 boxes are good and don't suck as much power from the drivetrain as the beefier T400 boxes.
Timmeh! When will we see you in a skyline again!?
This week! Fingers crossed.
If my vast knowledge of Mr Tim is correct he owns an r34 is in it as we speak
Your vast knowledge is correct. Well, I own it but I haven't got it yet - just waiting on compliance to finish up before taking it for a spin....
Nice one! Will be keen to have a look.
A spin up to see Chris right? Making sure that nobody else takes it for a spin ;)
Getting excited? In other news, WASSSSUUUPPP TIIMMMEEEHHH???
Hopfully it is all good. I dunno about that but if drag is your thing they have the runs on the board!
Happy Birthday big guy!
Thanks buddy.
Happy birthday mr ants :)
Cheers Nicky.
#@SCR48
Get a power glide, get a transbrake, do this >
^ this as well
Happy Birthday
Thanks Clint.
Happy Birthday Ants
That sucks wang.
thank you kindly
Happy Bursting out from your mum's vajajay day Mr. Ants!
Well put and thank you sir :laugh:
In reading about the G4 I was saddened to learn that it had to run wasted spark, Nek minnit, read a little further and Microtech makes a ignitor with 6 ignition drivers that you can hook up to the link for only 195 bucks, sweet!
Everything seems compatible with them
That photo makes it look like you got sick of it and took the Ant Eater to the wreckers :( lol
twas kinda of tongue in cheek :P
Have to say that EFI performance is really isolated due to those industrial / scrap yards.
When I was speaking to Sean he was fixing his dyno cause its got some issues.
g4 are good ECUs and pretty sure it will be able to adapt to what you require Bunts.
Guest
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
