Not for me. I rarely use FB chat.
I wasnt talking about you, I was talking about Nick, but now from that reaction I am suspicious of you too :P
Hey Tony, You know what we should do next year some time? Morgan Park. Its a cool track and we could do what the NSW peeps did/do? with Wakefield, Road trip up there, track day, then stay the night and get on the piss.
It's on the cards.
Can't wait to roll up next to an unsuspecting McFly, look over and smile and watch his soul slowly die as I hit this button
I cant wait till the cops roll up, see that button, look over and smile and we get to watch your soul slowly die as they bum you relentlessly for hours before giving you your notice to appear.
Edited by Bunta
I cant wait till the cops roll up, see that button, look over and smile and watch your soul slowly die as they bum you relentlessly for hours before giving you your notice to appear.
Hide the button *herdererp*
Nah I'm gona put it on my steering wheel with a big label "NITROUS PURGE BUTTON #hectick"
Best of luck to you, but i doubt you get away with any form of it for long.
Lies purge kits are awesome, I would shit bricks a car was sitting at me next to the lights and next thing I hear and see this thing purge a nitrous line and the stand on a massive stall... Thing of nightmares
On the street you should be more worried about something that sees all that, Says challenge accepted, dials up 9krpm and side steps the clutch and disappears leaving only 4 little black lines. AWD grip is very hard to beat in a traffic light grand prix.
I know which one looks more impressive...
that to a child would be truely terrifying.
i need one. keep those damn kids off my lawn
Dude if you came running out of the dark all oggity boogity and dressed like that I'd shit myself.... So would 98% of people, the other two percent would die
The only difference is a puff of girly gas.
9Krpm launches, especially with a ignition cut limiter look and sound amazing.
Flames > fluffy white clouds
Guest
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
