Piston 2 (this was the one that spun the bearings) (also on the top of the piston there is "050U" or similar indicating the piston is 50thou oversize)
Cylinder 2 Bearings
Cylinders 1 through to 6
There is also an indication of detonation on the cylinder head near cylinder 2 where the lip has been melted or watever (theres a big dent on the lip). Also we can pretty much gather that this engine has recently spun a bearing and has been pulled down, had the pistons and bearings replaced, attempted to be honed (can see slight honing marks in bores) and 50thou pistons put back in with new bearings that may likely have been the wrong size.
Well there you have it folks. One completely stuffed engine which i can almost just throw away.
If anyone is interested in coming and having a look or watever feel free, as its all in bits up the back, just give me a hoy :P
I've got no idea whats happened to it in it's past life. Ben decided not to tell me this information, so he's soon to get an ass roasting over the phone :@.
Going from how deep the gouges are in all the bores now, i'd be pretty certain for it to be re-used it'd have to re-sleaved. You can even see where they have tried to hone it as there are honing marks (cross hatching) on the bores! Also the bearings are pretty much brand new.
It also looks like the crank has been linished before too, so we dont know if it can be linished again.
BTW i got the car off DRAGTS on here, feel free to give him hell :)
so did u have an idea that the motor has been pulled apart before for a dodgy rebuild?? and say hypothetically, u were to use the stock bottom end again, can it be rehoned now its been 50thou over bored??
My Cef had zero mufflers.
So did mine... Its just Im doing a lot of highway kms, and the noise is just too much. I compensate it with the stereo, so then thats too loud and it does a lot of ear drum damage.
That and its just too noisy, Im over it.
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
