OK, rice it is :)
if the engine needs a rebuild, i'll do it, not a problem. i'll talk to dan about this but from previous discussions, the rb25det engine can pretty much handle up to 300kw's without a rebuild but thats not constantly running a large amount of psi all the time.
lately, i just been runnin stock boost (turnin the avc-r to 'off' mode) and whenever needed or wanted, i just flick it over to map A or B.
Some times they can handle 300rwkw, but the consensus these days is that it is really closer to 280rwkw, An engine that is old and has had a history of making power at high boost it is probably even less or in any case will not last for any length of time at that power, I would start planning the rebuild now as it can take a while!
or u can cheat by buying a pre-built one and do the swap in a day, hey andy :)
gtr is gone. sold it.
why would u do something like that? :rofl:
How is everyone today?
good mate, been out most the morning at millennium msports, got no work :rofl:
how bout u?
I would love to tell Shanef what I am doing today but he gets all upset when he heres about the good life too much.....
Oh, but I did pick up all my travel documents for the next two weeks!!
its fine dave, i've come to grips with the fact that all old people do the same stuff that you do :)
I held very little back over the weekend. I think the bass affected my judgement and lowered my inhibitions just a tad...... As evidenced by the groin thrust dance and the swear count on Majorsick!! I needed to take more photos of T-shirts as I saw some absolute pearlers at AS!! Have ordered more but these aren't too rude......
Ahahaha it was great. Swear count was good, I love having majorsick around, he takes the focus of me swearing :whistling:
OMG this place is pure gold today, I haven't rofl'd so hard in a long time. What a joke. Thanks for making my day :sorcerer:
or u can cheat by buying a pre-built one and do the swap in a day, hey andy :whistling:
why would u do something like that? :woot:
good mate, been out most the morning at millennium msports, got no work :devil:
how bout u?
Not everyone has sweet pedros cousins style hook ups like me but Shane
good mate, been out most the morning at millennium msports, got no work :D
how bout u?
Yeah i am good, jealous that all of you got to go to BAS on the weekend i was 1400 k's away.
But not next year
Guest
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
    • @Dose Pipe Sutututu I read your replies RE: R35 GTR MAFs, any ideal spots to put on? Obviously will need the adapter plate. Will be having a cross over intercooler fitted shortly, would putting it a bit before the TB be okay?
