bahaahah nah, no-one's that spesh! I am just super bored. The stupid temp just sent me an email that is actually quite humerous.
Anna!! are you haveing a go at Temps?? Hmmm??? :(
I used to be a temp!! :O
:( i did no work and still got the permernate postions :)
but still :no: dont even go there sister!!
ahah nah. i've been posting stories about this crazeh wench for a couple months now. deadset, she's a loony. I just hope I get to stab her before she gets me :O
ohhhh yehhhhhhhhhhhhhhhh!!!!
3 to 4wks from now, the exterior work of the skyline should finally be completed!!!!
leaving rear bar as the standard one.
changing the sideskirts
and as anna calls my wing a "shopping trolley wing"... that will be changed as well.
next wknd, interior work should all be finished.
Apexi RSM is on its way and fuel & air ratio gauge will be installed next saturday along with the full tein suspension i pickup tomorrow.
ohh yehhhhhh!
then early next year, i can concentrate again, more on higher power figures :(
ohh yehhhhhh!
then early next year, i can concentrate again, more on higher power figures :D
:D it totally is a shopping trolley wing :D you know how good it looks when you stand behind it and pretend you're at coles :laugh:
ohh yehhhhhh!
What brand of Tien?? Better not be super streets with thier tight non pillow top mounting :D at super streets
street and track racing.
buyin directly from fulcrum at coopers plains
Bah are they HA?? Super street?
Stoopid Fulcrum and thier half information
Shane that is the SHIZ lend them too me for the week lol
shuttup andrew you already have enough shit. you're already replacing the radiator, cat, turbo and getting an oil cooler. no more!
AND I'M SO SICK OF HEARING STEVE FROM IKEA. HULLO! NO f**kING HULLO! *stabs*
Guest
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
