It is poxy... in comparison to the 32 :D
I can tell :laugh: ahahahaha I'm just bored is all :D
The temp is talking to herself again. This time about sneezing and saying 'bless you'. But she's saying it to herself! "Julie, I know when you sneeze you say bless you, ooh bless you Julie, thank you very much now I know this piece of cake should really be eaten but I just don't know *sneezes* oh bless you Julie..." :D
And the other chick in my section is pissed! She had a long lunch and came back off her guts. So she's sitting here watching youtube pissing herself laughing.
That's why i want a 32 they just have that look about them!
I dont thrash either, and if I had to pick one it wouldnt be the R32 because it hasnt been healthy enough to thrash since July
yes, but it is being tuned on Monday, isn't it, so hopefully they can work out some kinks!
OMG have any of you read that Tampon Ad thread in the wasteland? Well too bad if you haven't i'm posting my bit in here. This website is the cutest ever! http://www.moxie.com.au/ sif you wouldn't want to buy their products with fab packaging like that!
You can keep our poxy 33
okay :D
Bingo
I was once told that Tien was the sony explode of the suspension world! Over Hyped but actaully pretty crap...and they had shock dyno evidence to back it up! But I cant say cause I have never owned any!
hard as a f**k, no rebound, and dont have camber tops. (had them on the 33 also :laugh:)
It better be fixed or I wont be happy!
Woot for hitman tune
and woot for engine going BANG caus u went dodgey on the radiator :D
we're going to 10 pubs around brissy...happening 2nd december
:D
:laugh:
I will be soon, i only wanted to know if i would be in the area or still up here. Spoil sport :D
when are you going to be here?
Guest
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
    • What basics? With these OBD1 ECUs it's not like the ECU will give you any real clues, it's not really doing any sanity checking of sensors/sensor data. My experience is actually a lot of sensors tend to be the source of the issue first and foremost, and checking everything gives you a direction to investigate. MAF/O2/STFT/LTFT should all kind of make sense. You can try little tricks of the trade like tapping the MAFs to see if it triggers a stumble, things like that. But once you've done a compression test knowing whether you have an air leak or fuel delivery problem is kind of hard to narrow down without sensor data. And you don't really know if all your sensors are making sense unless you can interrogate the ECU directly about what it's seeing for sensor data.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
