Anyways back to the topic at hand...
Lets whore some more...
Bryn... I just called Enoggera Smash for you as i know your lazy and they said no. Their too busy and booked out til Christmas. So maby try another well branded smash repairer...
They said they dont mind doing stuff like this, but said their not mechanics and can only bolt it up. If there is a problem it is the customer issue to fix. They said they make cars look pretty not make them run well...
Makes sence?
Not to mention you need to cut a few 3" holes and pull the front end of the car apart...
I would rate is as a 3 start dificulity out of 5...
Fitting GT30 turbos is a 4 star... :P
Changing the oil is a half a start... ;)
Pretty simple process, ur over exagerating it col lol
I reckon $300 labour is what most are going to charge you...
I remember the 3" hole saw and chuck bit was $110 from bunnings just for that one item i needed. So the tools needes are not cheap...
I could do it for you if i had time... But with work im not back in Brisbane for more than 24 hours until Christmas... :)
Id suggest All Star as richard has all the bits to cut the front bar...
Rubbish, it CAN be done with a simple old angle grinder :D (ur not gonna see any of it anyway)
Im a post whore...
Yes yes yes i am...
Post whore am I...
that not what the post count says ;)
I UNDERSTAND WERE YOU ARE COMING FROM... BUT YOU SHOULD BE TALKING WITH JOHN... HE THE ONE THAT HAS BEEN SAYING THAT SAU ARE SAYING THINGS ABOUT ME...
and when have i said stuff about u? the only person that woulda said 'stuff' about u would be john (thats if he did)
hmm i wont talk to dan, we had issues, as nice a bloke im sure he is, i will go else where. a mate of mine jsut said that, since you suppling all the parts, they charge more as they wanna make money off ya
well if u do something to annoy him, of course ur gonna have issues, just like anyone
Hey shane, the kit arrived, only took 36 hours, thats some good postage.
yeah that is pretty decent postage hey! so did u go with the just jap one? and if you want i could put it on for ya
P.S i go away for a few hrs and i come back to 2 new pages! :O:P
hmm, it would be great to have you install, but i dont think we are both ever free at the same time, and me not able to drive, i couldnt have you driving to redcliffe... so i either pay, or wait till december :s
Well said...
I have to aggree... I have not been involved enough in whore town to even start to understand whats going on.
I shrug to try and understand the situation, but if you belive im having a go at you your wrong. Cause im not sure what the topic is about???
Angle grinder....
Ewwwwww....
Ill never be that dodgey.... I like the satisifaction of doing a job properly and knowing it is done right...
yes, but when u dont know EXACTLY where that pipe (left hand side one) comes through, it's much easier to use the angle grinder than a hole saw...u end up with the same result, and its not a structual binding 'mod' so it doesnt really matter how 'dodgey' it is
besides, giving it to a shop to do, how do i know they dont get the knew guy (1st day on job) to install it, without watching everything he does, they could be worse than me :s
Guest
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
