Guess how much I have spent....you will hate me
nah no quarter mile time yet, I have had it since Feb this year....and been replacing stuff and trying to get ti to run properly since July :happy: lol
try finding someone to tune an FCONV...it doesnt happen in qld...so I used to have to contend with an extremely anoying idle and some very rich afr's. I believe that Matty Spry might have the software now though.
that's easily fixed, bust out the scissors, cut Mr HKS off and wire in Mr MOTEC :happy:
no idea... 20K?
And for the record that 13,250 is how much the car cost me btw :happy:
All ive changed is fluids :P
Ahhh I see in that case you are doing better than me :P
It would be good if he did have it! They are an awesome computer
With the 3037s what was the boost response like?
was going to but never got around to it and eventually sold the car.....to tempting. I need my license and it was annoying to go driving and worry about the police pulling me over for a check and going, excuse me sir but why does that screamer pipe vent into the atmosphere? (amongst otherthings) Im going to wait and have 2 cars, one for track and one for the street. Its a much better and safer equation. I do miss the fun though..alot!
money wise maybe - performance wise not :happy:
im not a childrens anymore though :P
have to make house payments now so cant just willy nilly buy things
am EXTREMELY happy with my car though! skylines are sooo cool!
Ahhh I see in that case you are doing better than me :happy:
It was good for a turbo of its size, I had cams which aided it, but it came on around the 3800-4000 mark at 1bar.
You will be first on the list Anna!
Hey when do you need the mone for the NYE thing. Looks like there will be 2 of us
sik sik subw00fa!
Money anytime mate, I just need to know if you're a DEFINATE. Including you 2, there are 8 definates. So I only need 2 more to get the discount :happy:
your right about the fconv too, they are an awesome computer...just very hard to tune being they are in japanese and almost noone in aust has the software. Other than that they have so many features and allow an amazing tune. My car had been tuned by garage saurus in japan but they must have made the map a lot richer when the car was sold because the afr's were a joke when it was dyno'd at millenium.
money wise maybe - performance wise not :)
im not a childrens anymore though :)
I have spent under 15k on mods...so I guess I am still doing ok!
Hmmm thats not toooo bad *ponders*
got ny idea what the 3037 garrett equivalent is?
you mean price wise or what the difference in boost response etc is? Garrett make HKS turbos and they also make a 3037...the difference is the wheels, HKS put different wheels in their turbos to make them respond faster and smoother etc etc...But Garrett turbos are cheaper than HKS, so i guess you way up the options.
Edited by 33NIZ
A GT30 somthing?
But I bet it isnt as good :)
Its nowhere near as good, almost all HKS turbos have an equivelant Garrett turbo being that they are both made the same. But there is a big difference in response and overall peformance. I have been in cars with the exact same turbos, HKS and Garrett versions. You notice the difference.
no no i mean wats the equivalent turbo in the garrett range i.e 3040R
A GT30 somthing?
HKS only come into their own with hi boost and big rpm, otherwise the garretts are just as good. and quite frankly, if u want to pay the extra couple grand for the 'better' hks then go ahead :)
dude that's rubbish. there have been people test each turbo on the exact same motor, and the only difference they noticed was the HKS provided marginally better performance at higher than normal boost (2bar+) and high rpm
sik sik subw00fa!
Money anytime mate, I just need to know if you're a DEFINATE. Including you 2, there are 8 definates. So I only need 2 more to get the discount :)
Cheers will have and a talk to the girl tonight and make it definate.
Guest
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
