He's a nice kid though, he doesn't care! He knows you just love your car :)
lol lukes cool.. he was revving my car the other day.. and we were standing there doing dr zoidbergs for about 5mins.. then nath walks in.. turns around and leaves again!
lol
SIG UPDATED!!!!
SKYLINE NOT FOR SALE ANYMORE!!!!
ahhhhhh yehhhhhhhhhhhhhhhhhhh
good work son!
lol
ahahahahah whoop whoop whoop whoop whooooop!
oh anna! I saw Lauren this morning :D
freakin user :)
Eep! Did you do breakfast with her or something?
anyone know where i can buy a duck from as a pet?
QUACK
*links sam to this page*
good work son!
nup! was I meant to? I was too smashed to even remember what I said to her, all i remember was it was pretty bad!
but I just looked at her... looked forwards and drove off! lol I got enough problems to deal with wihtout her aswell!
I think you can get them from like farm supply stores... well you used to be able to in kingaroy :P
Find a breeder, or check the paper.
How do I become a :) ? or at least dress up similar to one :D I don't have any :P wear
Oh turdy, go visit a costume store! They all have pirates of the caribbean costumes now! Or you could dress as a lady pirate. And wear a short ripped skirt and a corset :laugh:
QUACK
ahaha I don't know. I thought that must have been where you saw her :)
And yeh, you were pretty pissed about it. But it was all justified :D
I think you can get them from like farm supply stores... well you used to be able to in kingaroy :)
Oh turdy, go visit a costume store! They all have pirates of the caribbean costumes now! Or you could dress as a lady pirate. And wear a short ripped skirt and a corset :D
i said he has to go as a princess!!! lol
ahaha I don't know. I thought that must have been where you saw her :P
And yeh, you were pretty pissed about it. But it was all justified :P
yeah... built up over a number of years
all good now!
shane.....
how hard would it be for us to prime sideskirts and side guards????
if u want a decent job, we cant do it caus with 2pac u need to do it in a spray booth (i looked into this all yesterdya for my car :))
Yeh we had that issue with the grill :) We wanted to paint it ourselves and autobarn were going to make up the paint, but the came back to us and said 'un, nah. You need to get it done professionally'
Yes. Turdy you have to go as a princess.
Oh turdy, go visit a costume store! They all have pirates of the caribbean costumes now! Or you could dress as a lady pirate. And wear a short ripped skirt and a corset :)
hmmmz
Need to watch pirates of caribbean again me thinks mmmm keira knightley... mm the accent.. mmmmm
sif :D
to hire?
screw that
that bodykit shop at underwood quoted me $180 per sideskirt to prime and spray.
$250/each for the front guards
$100 for both of the review mirrors to be primed and sprayed.
thats for them to do the job. not me.
i just drop the gear off to them and they do it all for me.
Guest
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
