Link 1
Link 2
Link 3
Link 4
Link 5
Link 6
Link 7
Bit of a mixed bag, price’s are still all over the place, wouldn’t want to spent anymore then $12k tops on a Gtst with mild things to be honest.
I’ve already had one maroon, two white, and one greyish green colour one, so duno if I want those colours again, perhaps Silver of the Blue this time.
HAHA :ninja:
I've been looking at those 7 links you posted before. You planning on doing engine work obviously, so kays wouldn't matter, correct?
Does buying from interstate concern you, coz 2 are in Victoria.
The blue one has a nice straight body, just going on the reflection in the photos.
having the day off rocks, its the bit when you've done everything you need/wanted to do and your starting to get a bit bored which sucks.
I have more yellow primer now, i should Primer my boot and hood for that added D1 style
HAHA :ninja:
Car can be from Vic or QLD. NSW would make it harder, but if it were cheap enough… Anything can be done.
Ideally I want a turbo shell with no motor of box. I don’t need trim either. But Then I have a car that doesn’t run, and project idea’s that will never happen, rofl.
Yeah quite a bit of engine work down the track, just need a car that is straight. Kays aren’t a huge concern. I’ll just clip the clock if its too high anyway.
you should come into the main land so i have something to do....Im thinking about going up to noosa exhaust and getting them to take out my centre muffler and put in a straight pipe....dunno what it'll sound like though..im getting impatient with my silent exhaust.
Means I have to get fuel, which is effort. Us Island foke don't have servo's hahha. Straight pipe you say.. Interesting. I heard a IS200 on the weekend at goldy, was ok... Can't say I would be putting a "cannon" on it down the track though.. *cough Honda cough*
Just the centre muffler could be aite,,
Guest
    • Well.... it's not just "de-oxygenating". If you do that you just have, most likely, ethane. So you still need to do a synthesis step to combine a number of ethanes/ethanols to make circa-8-chain hydrocarbons. And of course you don't want straight chain HCs, because n-octane actually has a negative octane rating (ie, it's worse even than the n-heptane which sets the zero on the octane scale!), so you have to do some tricky catalytic chemistry to synthesise branched HCs. That's all doable - but it doesn't come for free. And.... it starts with ethanol, which is an agricultural product, and there will almost certainly never be enough of that as a base stock to replace the liquid fuels that are in use. You really wouldn't want to be planning to be using any more ethanol for fuels than is currently already used (in E10, E85s, etc). And ideally you'd be looking to reduce such usage, as it is largely wasteful, particularly in the stupid-ole'US-of-A where the corn lobby has organised it so that it's actually primary production corn that is used to make a lot of the ethanol, not by-products and waste, like it is (mostly) elsewhere. So, what I said about needing free-ish energy probably still applies. True synth fuels would be made from H2 and CO2, in a near reversal of the combustion process. In fact, given that the H2 would be split from water first, it actually is a complete reversal of the combustion process. But...energy intensive. The human race burns something like 1 cubic MILE of crude oil, after it has been made into various fuels. Every year. That's a simply stupendous amount of energy. Just assume that the density is 900 kg/m3, and that the calorific value is 45 MJ/kg, then that is 165.9 x10^12 MJ of energy. Or more than 10^19 Joules. You get a maximum of 1 kJ/s per square meter solar radiation falling on the planet's surface, and so if you halve that for daylight, and halve it again for average weather (highly optimistic) and then take ~25% for the very best efficiency of solar panels, then you need about 85.7 billion square metres of solar panels to generate enough electricity to replace that liquid fuel energy consumption. Each panel is about 1m2. That's a rather large number of panels. We also burn about a cubic mile of coal. We also use hydroelectric power. We also use nuclear. We also use a number of other sources, both "renewable" and not. You can kind of ignore the renewable ones (except for hydro, because it will all end up getting subsumed into pumped hydro for storing other renewables, and so it won't be the standalone renewable that it originally was), so we end up needing a multiple of the ground area number that I just arrived at.
    • Corvette thread then? Don't say I didn't predict the future again. "I love the little MX5, I do, but I just want something a little easier to get in/out of, a little more cushy and some power would be nice - I miss the V8 Rumble... I found this clean red C5 for sale recently and..." I'll do you a great deal on the next step, which is one of those but you can fit people in it, too.
    • What about renewable diesel and/or gasoline? I see some projects spinning up like de-oxygenating ethanol to make drop-in compatible bio-gasoline especially in CA. I still think the future is EVs and we should've all gone full throttle on nuclear power after the 1973 oil crisis like France. Despite 15 years of work in CA to reduce the CO2 intensity of generation with renewables our electric grid is still far worse than even "low carbon" nuclear power. ICE is pretty cool when you aren't depending on the stupid thing to be practical and reliable and cheap as possible to get you to work every day. It's kind of like mechanical watches or vacuum tube amps.
    • I just rolled over "my" first 10k km in the MX5 Every time I go anywhere it always ends up in a adventure to look at houses and find some random country roads I've been on leave since early November but unfortunately need to go back to work on 19 January Luckily though I still have a fair chunk of leave left to burn until.... Not that I'm counting 😁
    • These look like S13 wheels.  And Welcome!
