HAHAH true that. I'm comming down for New Years as well, f**king guna run a muck.
That chick looks hot from the back hahah, 10 points to the dude
Thats all thats important isnt it? What they look like from behind!
Finally, I get my R33 tomorrow! F*ck yes!
Got any pics or more details mate?
Stylish Shot =P
Corner View
Arse Shot
Front View
Inside Shot
I've had it under contract for weeks now, waiting for finance to come through, well. It came through about an hour ago =D.
Like in my sig, it's a 1993 R33 GTS-T with 73,000kms on the clock.
Stock as all the way through and is in perfect nick. One Japenese owner, it came off the boat about 3 months ago. Full RWC and yes, the import plates are still shiney =P.
It has fat as tyres on the back and it's been factory lowered. Thats about it, apart from the fact some bastard stole the gear knob so it has a shitty one on there =P.
Ok, let me see if I got this right........ a 1993 with 73000 on the clock???
Let me guess, it came from a dealership near the PA Hospital?? Not saying it can't happen, but you have to realise how rare that is........
Actually I didn't realise it was that rare, makes me feel even better =D
Hahah, when I got the Nova, it only had 72 on the clock, thus being a 91 too.
But yes, you shall all see it and see the kms and see that I am not a lying whore =D hahaha
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
