hmm anyone intersted in a half day fishing off the gold coast ? I am going wanted to see if I could get another car nut to come with me :)
http://www.redballoondays.com.au/experience/FFC581
if this is the same Eddy (aka EnGaGe)? if so yeah he does have a black 33.
Yes the one and the same
*e-touch* dont tell marc
OK *shhhhhhh*
same person i'm thinking of?
Dunno LOL...I'm referring to the charming beauty Marc previously had as his avatar *shudders*
She's gone? still showing up on my pc. Damn caching proxies.
SUX2BU then :)
I got bunny straight away :)
i would go ply wood personally. i used to use a lot of it for modelling purposes when i was younger. cheap, fairly strong and not too heavy. eithere that or mdf. check prices really, both should do fine for what you need
bit of a spoilt brat, mommy pays for his shit.. wanker.. absolute wanker..
bought rims off him..
yeh, thats him!
bet he hasn't done any shit to it though like he said he's done.
his mum spoils him hey? i would of thought it be his super-daddy lawyer he has.
rofl
i'd go with ya this wk as there is barely anyone here in the office to provide any work for.
but, unfortantly all my $$'s is being invested into my new railway system im building at home :)
yes but in event of water the wood won't swell (ie when you build your mountains etc).
yes, i could just make a small pond out of plastic from a mold and do this.
but then that would involve filling it up every now and then from the water evaporating.
that i would think would be against water restrictions.
lol
Guest
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
