i`ll tie the cat down tonight to the track and video tape it :)
no, soak the kat in kero then tape it down to the tracks, when the train starts moving the electricity will set the cat on fire, then put a big sharp spike on the end of the train and watch :D
ok, i'll admit that was a little too evil :)
Edited by lilmike86
yeh, thats him!
bet he hasn't done any shit to it though like he said he's done.
his mum spoils him hey? i would of thought it be his super-daddy lawyer he has.
rofl
yeah i doubt he has either...
hung a bit of shit on me and my mate since we are more into track days, motorkhanas and stuff...
openly told us how he likes to drift in some industrial estate - then the topic of insurance came up and he told us he didnt have any. and that if he crashed the skyline his parents would buy him another one. then blah blah RB26 transplant for drifting, blah blah.
if i recall correctly, his parents run an metal yard.
p.s - 40ppp :)
p.s - 40ppp :)
rofl!
a metal yard?
no wonder he's dumb as shit
he probably got his in the head with flyin metal on a day to day bases when he was yonger
and played around in the dumpster of a place.
yes...yes you did mike and i am now scarred for life.
did you see oprah troy? did you? you can tell me.......its ok troy. just calm down and breathe. its gone now, you'll be fine. now lets never speak of that again :)
man! did u see that women's ass?
its as wide as a football oval with dead grass thats never had water before!
only the acidic sweat of the hose-beast herself filled with the laughter and tears of american idiots compressed into droplet form. purely diabolical indeed. only such a thing could come out of the United States.
:) <- oprah at lunch time
if u think only such things like that can come out of america
wait till u see wat the afgani's can pull out of there ass.
trust me, its one serious threat to the whole world when u see wat can come out of there ass!
yes but the afgani's have beards...............wait, so does oprah? hmmmm..............this complicates things indeed.
maybe that explains the origins of the hose-beast known only as..............oprah winfrey..........and her gigantic ass!
*insert dramatic shock music*
Edited by lilmike86
Guest
    • Welcome.  800hp should be a bit of weekend fun!
    • I'm going with "Just run two gates". Fix the problem conclusively. It's the only way you'd ever truly know, right?. This is all pretty much splitting hairs. Even the extreme example where it takes two whole seconds at 100kmh or something sounds monstrously dubious. And anyway, when you're punching the throttle when you 'need' this power, you aren't at 2800rpm in the wrong gear. Test it at 5600rpm in 3rd gear, when you're traction limited punching out of a sweeper. Much difference there when you account for traction?
    • And the full R32 GTR wiring diagrams are also freely available. Hmm.... there's supposed to be an auto replace that would have linked the thread. Here it is, manually
    • Ahh...should have been clearer ~ there's 2 ... SMJ = super multi junction (connector)...   ...this is connector 6 & 25 in above image -- body harness to engine loom (6) & body harness to main loom (25) Headlights go to front via connector 6 ; fuel gauge goes to tank sender via connector 25  ...like I say this is R33 diagrams, but at a pinch R34 won't be too far different. *IF* the two ground faults are related, this can be the only place where both wires converge (as one runs to the back, the other to the front)... ....thing is, you probably need to establish if the faults are related (unless you examine that area and find obvious chaffing on the looms there to body ground)....*IF* the fuel gauge is still broken (full needle deflection), I'd be headed for the boot, remove fuel sender wire, key on and measure the voltage there ~ it should be roughly 10volts. If that's ok, check sender to ground resistance...if this is a dead short to ground (and there's fuel in it), then sender has failed or something funky has happened to wiring in the tank. edit: ahh...rereading the thread, this is R32....above fuel sender test still valid tho'
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
