I agree r33skyliner ^^^^^^^^^^
I only been on here for a year or so
When I first joined the forums I asked some stupid questions (lol doesn't everyone when there learning??) and got slaughtered by a few of the more senior members, learned my lesson quick. But anyway of the events i have attented (I should attend more often) I have foun the other SAU members to be friendly and easy to get along with etc etc...........................................................
peace out
  • Replies 61
Posted Images
Why don't you all come along to QR on Sunday afternoon and have a big hug in :O
In between hugs, you could extend a little support to the lone White Skyline which will be battling it out all afternoon against a bunch of other makes including a GENUINE Ford GT40, 2 Le Mans Porsches, Several Porsche GT3's, several Alfas and an assortment of WRX's and a Lola T70'
There is no doubt...we will be feeling VERY unhugged :O
Should be a good day...race starts 2.30pm finnishes 6.30pm or 160 laps whichever comes first.
Why don't you all come along to QR on Sunday afternoon and have a big hug in :)
There is no doubt...we will be feeling VERY unhugged :(
Sounds like it'll be a good day... might try to convince Karen to come out for a look :ermm: Besides, I haven't seen your 33 in action since it went to the drags stock but stripped out... and I want to see the GT40 and the Lola ;)
... a GENUINE Ford GT40
:O Kodus to the guy for actually racing the thing, I'm not a fan of hiding race cars away in a climate controlled garage somewhere and never having them move except to be detailed.
I'm in.
Would like to say a huge Sorry to both Mark and Jay for some shit which i have said, i know its long overdue but thought it best to take a bit of a break for a while before some more stuff was said.
So anyway's a big Sorry to both of them and to everyone else who i have offended (no doubt there is a few) over the past few months.
  • 2 months later...
awwwwwww isn't this a lovely thread! What a nice way to start my Friday. By reading all the love that these men have for each other. It's just one great big SAUSAGE FEST!!! :(:)
In the spirit of this thread, i'd like to say Happy Friday to y'all, and if anyone's bored tonight, I will be out, so holla and we can meet up for a :D
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
