Problem:
My S1.5 R33 used to missfire from around 4500rpm til about 5500rpm @ 12psi+ (especially in the cold). I tried everything, from installing an SAFC II piggyback to tune the AFR to regapping my spark plugs etc.
Solution:
The stock coil packs have a hairline split on the side of them, which at high boost levels, the spark tends to not follow through to the spark plug, but jumps out of the coil pack. After sealing up all my coil packs, my car runs much smoother now, I can boost it to 16psi and I dont get any missfiring.
D.I.Y. Fix:
For a quick and cheap fix for this problem.. (the following was done with spark plugs regapped to 0.8)
R33 GTS-t Fix (Im guessing that the same problem occurs on the R32 & 34):
1. Take off the plastic cover in the middle of the engine (between the tapper covers) which covers your coil packs
2. Unplug and unscrew each coil pack (all six) and take them out
3. Holding the coil packs vertically, inspect the sides and locate the hairline split (as shown below)
4. Once you locate the split, using GOOD electrical tape (cheap stuff WONT work), tape over the split a couple of times, making sure the tape sits flat over the split and seals it firmly (as shown below)
5. Once you have taped up all 6 coil packs, screw them back in place and reconnect the plugs
6. Place your plastic cover back over the coil packs (I have left mine off for better cooling of the coil packs)
Done! :P
MORE HELP:
For more info on taking out the coil packs ---> http://www.skylinesaustralia.com/forums/in...showtopic=42819
Another alternative is buying Splitfires, but this is around $700+ dearer to do..
PS. Make sure you use GOOD electrical tape, as cheap stuff tends to get hard and peel off from the heat.
EDIT: Or as QRI05E recommended - for a more reliable seal, use 'Shelleys Industrial Silicon Sealer 401' for only $11 @ Bunnings.
Edited by MKDR33
https://www.sau.com.au/forums/topic/119403-how-to-fix-missfire-problem/
  • Replies 149
Posted Images
The tape will eventually soften and shrink due to heat... a much more permanent method would be to use Shelley's industrial grade silicon which is heat proof till 205 deg/C... $11 at Bunnings and has got rid of all of the misfire…
Cheers
these must be series 2 coils series ones are different, atleast they are on my mates seddan. the coil goes all the way arround, so the only way to fix any cracs is to epoxy the entire thing, as we did.
simply dipped the whole thing in 2min epoxy, worked well.
Epoxy glue is excellent for bonding materials however loses strength above 65 deg/c and considering that silicon is a MUCH better insulator and the Shelley's ind. silicon can withstand 205 deg/c makes it a much better choice...
i went to bunnings today and bought Shelleys Industrial Grade Silicon Sealer 401.. Removed the electrical tape from the coil packs and resealed with some silicon.. waited around 4 hours so it dries up nicely n took the beast for a thrashing..
i must say, it does seem more reliable to use the silicon.. when i took my coil packs out today, i did notice the tape had shrunk a bit a little bit over the split..
  • 1 month later...
  • 3 weeks later...
Guest Rotary20B
Hi,
I just pulled my coils out, plugs will have to wait till I find a proper plug socket for it
Anyway, I couldn't see any noticeable cracks, only what looks like casting marks
My S1 coils are different to the ones pictured above too
Should I just seal them up anyways? Or wait till I get the plugs and a socket tomorrow and just try re gapping the plugs?
The coils have a bit of oil covering them too, don't think tape would stick too well, whats the safest thing to use to clean them up?
Also, has anyone tried self amalgamating tape?
This is, mine only stuffed up after I upgraded the exhaust
So I thinking it is just the plugs need regapping
Edited by Rotary20B
had a simmilar problem, so i took out my coils and allthough they all had thesam resistance and no cracks visible, i wrapped them up for good luck, i took out the plugs to discover it had two different types, no wonder it had a missfire.
So i changed the plugs to BRK6AYE or something like that, gapped to .8 mm and all good, pulls way harder and no missfire so far.
YEEEHHHA, bring on the boost
Mine did not have any cracks, pulled them out twice and checked them, one thing you cant visually check is wear. Waiting for my new splitfires to come from Japan, cost $540
I couldnt spot the cracks on mine either but I taped them up anyway. Problem solved. Off to bunnings to guy some silicon
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
