  • Replies 149
Posted Images
I used normal silicon on mine as its all I had in the shed. :O
It HAS stopped the pop and break down BUT I can still see a little flashing of the coils at night with the centre coil cover off.
So for me.. its worked.. but there still is a little arcing out. Where as before I would experience pop at 11psi I can now ramp up boost to 1bar and there's no pop.
Pics of cracks in the coils, do note some cannot be seen by eye. You need a magnifying glass or camera in macro mode.
http://www.skylinesaustralia.com/forums/in...st&id=63009 <<< Obvious crack
http://www.skylinesaustralia.com/forums/in...st&id=63010 <<< Cannot be seen by eye but camera picked it up
http://www.skylinesaustralia.com/forums/in...st&id=63012 <<< And the finished job
Excellent pics Cubes. They should help a lot of people.
Are they Series 1 or 2 coil packs?
Guys, I have a S2 1996 R33 GTS-T.
I have only just noticed by car misfiring in the last week.
Started boosting my car to 12psi (mods include fmic, pod, cat-back
exhaust) and started misfiring around the 3000rpm mark. Took
the boost controller off and now it's missing once the standard
solenoid opens up at 4500rpm and hits 7-8psi. There is a
substantial loss of power in this rev range.
I have bought a set of second hand series 2 for $100
and am going to get these installed later in the week by
my mechanic. Hopefully it does fix the problem!
They are R32/R33 Series 1 coil packs.
Do remove the coil cover, secure your ignitor, get the car warm and at night check if you can see a lightning show. Its a sure method to determine if your coils are on their way out.
Mine still arc out even though there's no noticeable missing.
Second hand coilpacks wont help dude. They are stock and will still missfire unless u seal them correctly.
Edited by MKDR33
Hi all, great thread. I can't believe such a simple idea works.
My car is experiencing a different problem, but my mechanic is sure it is the coil packs and wants me to replace them with Splitfires.
The symptom I have is: When the car is in neutral, if I rev to around 2000-3000rpm, the car splutters and spits (misfire?). It also seems to effect driving when I am coasting at one speed. When I am accelerating or decelerating, there doesn't seem to be a problem.
I've recently had a the fuel pump changed (becuase of a missfire issue under load at around 4500rpm - seemed to fix the problem) and the timing belt changed (I thought it was about due) as well as a service including spark plugs. The problem seemed to start after this. In the last week I've noticed my check engine light come on 3 different times while driving on the freeway (knock sensor?).
Does this sound like a coil pack issue?
My car is a 98 R34 GT-T.
Thanks for any input.
Sounds similar to the problem I'm having.
I recently replaced the turbo drain hose and has appeared to make the light cruise miss/surge a touch better but it still comes and goes.
Watching what the o2 sensor is doing when mine does this it reads lean. I am soon to rip the head off and do a few other things so I'm hoping I fix the issue in the meanwhile.
It 'could' be coil related... poor spark under certain conditions = an incomplete burn resulting in the o2 sensor reading lean. Or it could just be a few stuffed injectors.
How does yours feel when cold, noticeably worse?
Thanks for the quick reply Cubes. I'll do a comparison tomorow morning when it's cold against after a long drive and let you know.
I took it to the mechanic yesterday and told them the engine light had come on. They plugged some sort of hand held device into a wiring loom under my dash and read the errors. The only error was something to do with the o2 sensor. Does this confirm your theory of coil pack can lead to bad o2 reading? Or does this mean my o2 sensor is stuffed?
The mechanic did mention the other likely cause could be blocked injectors?
  • 4 weeks later...
Definately one of the best DIY threads ..huge $$ saving solution.
My stagea was misfiring all over the shop on idle ...especially on a real hot day...pulled the coils out last night and smothered the coils with heat resistant silicone...got up at 5.30am this morning to put everything back together and now the car idles like a kitten.
cracked the breather hose putting it back on but that was coz it was brittle with age (using electrical tape as a bandaid fix)
there were 2 high temp silicone gels available at bunnings..401's which are heat resistant to 205 degrees ....and another one which which had a 4 hour fireproof rating
Had time to think about the whole thing though...now since most of the cracks seem to appear to the side or bottom of the coils where it meets the rubber boot...then closest metal object where it would spark to is the metal cradle that holds the coils...i took extra precaution by running a thin layer of electrical tape around the cradle too << just thought its something u guys might consider doing.
  • 3 weeks later...
hey Guys I have r33 GTS4 NON-TRUBO, but still got a miss fire, I want to give it go, whats the spark plug regap should be since its a non-turbo? 0.8mm ? please let me know
non turbo shouldn't need to be gapped down.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
