Ripped out my coils today and had a look, they seem to be fine, couldnt find any cracks, they looked brand new basicly and the plugs looked fine to but still has a miss :wave:
  • Replies 149
Posted Images
well you think that is problems, READ THIS, got new splitfires and no differance, must be something else, BUT WHAT?
if its not a coilpack problem, it might be your spark plugs needing to be regapped or it might be an AFR issue..
i dont have much experience with R34 GTT coilpacks dude, but you could try taping up across the middle of the coilpack as described (shown) on page 1 of this thread and see how u go..
you CANT really see the hairline crack on the coilpacks, but its there and is the cause of the missfire in most cases.. if this isnt the case, then you might need to regap your spark plugs to 0.8 and check that your AFR isnt running too rich..
Plugs are allready gapped to 0.8 running stock ecu, the thing is one week it will miss then the next week it will be fine, so im not sure if its the CAS as some ppl have said they had troubles with it
damn paid $13.45 at true value.. i aint travelling to bunnings another 15kms away to save $2.45
pulled them out 2 nights ago upon inspection none had vissible signs of cracks or marks.. so i decided to bast them with silicon 401 as a DIY thread suggested. waited a night and put them in.
started it up warmed her a bit. and took her for a drive still had miss. but it was more upwards of 6000rpm.. had more lower down torque. but still wasnt fully driveable.
parked it in the driveway.. gave it a free rev held it at 4k to see if it would splutter. and it didnt. then took it for a drive again and it was better. came back. decided that i would try to cool the intake temps to limit chances of detonation.. so i threw some cold water on the SMIC and took her for a drive. revs fine all the way to 5500 and cough and then to redline..
after a while it ended up fixing itself..
now my guess is the ECU adjusted itself a littlebit as it went on. or due to lower air temps ther was less pinging and it helped out. thus cleaning out any hot spot carbon deposits from the head leaving it clean..
sound right..?
sound right..?
usually the pinging occurs in winter at cooler temps, the rest sounds right..
ok. i did mine :( it works!!! although still coughs at about 5000, and doesnt have the same power like it used to when the boost kicks in, but much better than before, it was impossible to drive, now im thinkin it could be the plugs since i didnt put them in and i dunno what gap is it set at
  • 1 month later...
  • 3 weeks later...
Just to let you guys know about my issue, I was having a missfire on my R33, i went out and bought spitfire coil's and put them in, there was a little bit of a change but the miss fire was still there. Got new spark plugs, that didnt make any difference....
i took apart my AFM and cleaned that out, still nothing....
After talking to some people, the only last thing they suggested it could be was the Crank Angle Sensor, so found another skyline and removed it from that and put it on mine....It worked like a dream, went out and bought a 2nd hand one for $150 and fitted it on. Now i dont have any problems....
Hope this helps some people that can't figure out what is causing their missfire.
Edited by Crash.
I have another theory to what could cause this misfire problem, on most skylines with increased boost (10-12psi on stock ECU) the ECU dumps a shitload of fuel in in the midrange (~5k) looking at any dyno chart will show this.
On my dyno chart it dips down to 10:1 however I have been informed that most wideband sensors can't read accurately below 10:1 so its probable its going all the way down to 9:1. This is rich enough to cause a rich misfire. It makes sense as the colder the weather the worse it happens, weak coils would just mean that the richest mixture they can ignite is raised hence new coils/taping them can fix it depending on the severity of the problem. I am getting my ECU remapped tomorrow and we shall see if this fixes my misfire problem. I purchased splitfire coils as well which helped the problem slightly however in cold weather it still misses, there probably are several causes to this issue however I believe this might be one of them.
Thoughts? Anyone in here have a remap/stand alone ECU and have misfire problems?
What sort of missfire did you have Crash?
A consistent high rpm pop or just every so often? Did it ever completely drop a cylinder then idle smooth back out after a few seconds after a high rpm rev?
When accelerating past about 1500RPM till about 4500RPM the car would missfire all the way inbetween, it was just a constant stutter, like the car was struggling....
When getting to high rev's it would just dissapear, the missfire was very noticable in 1st and 2nd gear....
Edited by Crash.
    • Hey guys I’m chasing a Rb20det complete or bare block need a good running engine as mine has low comp
    • You're making my point for me. 95 is not "premium". It is a "slightly higher octane" version of the basic 91 product. The premium product that they want people to buy (for all the venal corporate reasons of making more profit, and all the possibly specious reasons of it being a "better" fuel with nicer additive packages) is the 98 octane stuff. 95 is the classic middle child. No-one wants it. No-one cares about it. It is just there, occupying a space in the product hierarchy.
    • 98 and 95 have to meet the same national fuel standards beside the actual RON.  91 has lower standards (which are quite poor really), so 95 is certainly not 91 with some octane booster. It would be an easier argument to claim 98 is just 95 with some octane boosters. Also RON doesn't specify 'quality' in any sense, only the octane number.  Anything different retailers decide or not decide to add to their 95 or 98 is arbitrary and not defined by the RON figure.
    • Anyone know alternatives to powerplus tungsten? Can't find an alternative online.
    • 95 is just a scam outright. 98 is the real "premium" with all the best detergents and other additive packages, and at least historically, used to be more dense also. 95 is just 91 bargain basement shit with a little extra octane rating. Of course, there's 91 and there's 91 also. I always (back in the 90s early 2000s) refused to put fuel in from supermarket related fuel chains on the basis that it was nasty half arsed shit imported from Indonesia. Nowadays, I suspect that there is little difference between the nasty half-arsed shit brought in by the "bargain" chains and the nasty half-arsed shit brought in by the big brands, given that most of it is coming from the same SEAsian refineries. Anyway - if there's still anything to that logic, then it would apply to 95 also. 98 is only made in decent refineries and, as I said, is usually the "premium" fuel, both in terms of octane rating and "use this because it's good for your engine because it's got the unicorn jizz in it!".
