i had the missfire in high revs up around 6000rpm but only in third
i have a high flo turbo running 15psi with an apexi power fc
so changed the plugs and made the gap a bit smaller, goes well in third
but does it a bit around 5 in fourth
should i silicone the coilpacks or jus change the gap some more??
cheers
  • 3 weeks later...
  • Replies 149
Posted Images
Firstly great DIY guys...
I have a r34 gtr and its having similar issues as some of the ones stated in earlier posts, under WOT the car would feel like its hitting limiter at about 5.5k-6k RPM. I have just noticed this problem ever since it has become colder...
I'm keen on trying this out over the weekend as a quick fix till I can source some splitfires. I plan to silicon then tape for extra measure. Although my question is, when a coil pack 'fails' what tends to fail within the unit?
Cheers
I have an r32, it had a bad misfire at 1.1mm gapped plugs (which i put it after i bought it, a mini service) the ones I pulled out were 0.8mm and the misfire was still there but not as apparent. With 1.1mm it misfired from as soon as the PSI started going positive.
Anyway, $400 later and some JJR coilpacks are in and its smooth as silk.
Don't bother with half assed fixes, just bite the bullet and pay the money, its well worth it.
  • 1 month later...
  • 7 months later...
Hey i got an r33 GTS, non turbo of course and i had the miss-fire issue too but it was only on idle once the car had warmed up.
I did the tape fix to test if it was the source of the problem and it ran as smooth as a baby's arse.
Went to bunnings and did the silicone thing today and they'll be back in tomorrow after school.
Thanx and yet again SAU to the rescue for $10.
  • 1 month later...
Hey sorry to bring up an old thread but is that stuff still called Selleys 401? I went looking for it at Bunnings, Placemakers, and Mitre 10 and noone have it. I noticed the original post of this was in 2006 so it could have changed name? Also i live in NZ which may have something to do with it.
This is the stuff mate
Selleys Silicone 401 RTV
This fix is hit and miss, getting splitfires is your best bet if it doesn't work.
Also having a rich tune and poor sparkplugs compounds the problem, making sure you aren't running lower than 11.5:1 will help dramatically as well.
  • 2 months later...
Hey sorry for digging up an old thread.
I did this fix today with the silicon, after putting everything back and fired it up, I'm now getting white smoke..
What could be the problem? I'm positive it's not condensation.
Never mind, it was just condensation.. took awhile to get rid of though :blush:
This fix worked a treat, had a minor flatspot problem that was fixed along with the misfire!
The missus did most the work, took everything apart and applied the silicon on the coil packs.
Had to take off the intake manifold as it blocks the coil packs, such a pain :)
  • 3 weeks later...
i had a misfire issue as well and i tired everything , but the fix for my car was the fuel filter..i went down to repco and got myself a new one , changed it over and i was running normal again.
once the old fuel filter was out , i blew through it and blackish petrol came out of it , so a bad batch of fuel along the way caused it.
I had same issue, misfiring under acceleration and a rough idol. I replaced the filter and the problem seems to be be fixed. Had previously checked spark plugs which were fine. Thought the fuel filter would be a cheaper/easier fix and so far seems all good.
  • 3 weeks later...
I did this today. My coilpacks visually look fine, but my head tells a different story. There are visible "lines" on the head at around the level of the joints of the coilpacks' plastic moulding. My theory is that this has been caused by the spark jumping from the coilpacks to the head. Over years this has led to the head pitting and causing the lines you can see in the photo.
I'd be very interested to see if anyone else notices this on their head.
Circled: Pitting in the head
Different sides & different coil packs:
  • 1 month later...
  • 1 month later...
  • 1 month later...
hey guys i got a question about my skyline lol, well just like urs its miss firing and the engine lights on n ive been everywhere with quotes and have six different diagnosis' can u let me know which u think it is cause when i hit around 60k's the whle engine shakes maybe a transmission problem or coils but either way its gunna cost me unless you guys can help?? i dont really know that much about engines but i love my 34 :) so yea help needed
Thanks From Erin <3
  • 9 months later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
