  • Replies 149
Posted Images
Has a haltech piggyback, running 14psi, if that helps? I'm completely stumped on what it is, only started doing it after I changed my clutch which again doesn't make sense, coincidence, was thinking maybe when I jacked the front of the motor up to get the gearbox out I've bent a cable or plug or something?
Should also include, has front mount, ssq bov, haltech piggyback, adjustable fuel reg, 3 inch exhaust, spitfire coil packs, walbro fuel pump, brand new plugs, pod filter, standard afm, stock turbo 14psi tuned by pulse racing ( old owner took it there) manual boost controller
  • 3 months later...
Has anyone got pics of there coils after applying the silicone 401 rtv stuff?
I'm doing this next weekend, do I rub it on with my finger or dip them in a bowl of it?
Thanks in advance.
  • 7 months later...
I don't have that Selley's high temp silicon at home, but I do have red RTV silicone gasket maker which takes temps up to 343C.
http://www.permatex.com/products/product-categories/gasketing/gasket-makers/permatex-high-temp-red-rtv-silicone-gasket-detail
Would this work in the same way that the Selley's would?
To answer my own question, I tried using the red RTV silicone gasket maker, wrapped my coilpacks in electrical tape and took my car for a drive.
Car didn't misfire from 5000rpm+, but now sometimes hunts on idle. Will see how it holds up after Haunted Hills this Saturday!
  • 4 weeks later...
what temperature grade of tape did you use?
what brand?
I used a house brand (Repco) electrical tape which cost me $1 for the roll. I assume you're in Canada from your name, so to explain, Repco is just a standard auto parts store.
My opinion is that the silicone is what's sealing it and the tape is just an extra measure on top in case I didn't get a 100% seal.
Also lasted a full track day with no missing.
Edited by dan.1337
  • 1 month later...
Iv got a s2 r33 and about a month ago after driving it in the morning by the afternoon the car sounded like wrx, so horrible miss to dropping a cyclinder. I changed the coil packs to yellow jackets, new spark plugs, new coilpack loom and a new oxy sensor. Car ran sweet for about 3 weeks better then ever, more power ect. All of a sudden driving her today started her up after driving from one place to another and it started a lil strange like it did the first time it happened. Turn key and its startes with a bit of a bang like too much fuel, so a high rmp start somehow and then back to sounding like a wrx. Only time car sounds normal is on the coats down from reving the car. I am now stumped so need some help
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
