This is not the for sale/advertise my wares section.
anyway, i would rent a car if i had too.
Putting stock cermic turbos back on there potential, and more often than not will cost you a motor.
Thats upwards of 5K
Its your choice, people give you good advice.
https://www.sau.com.au/forums/topic/119429-r32-gtr-turbos/#findComment-2218060
So are you recommanding putting aftermarket turbos on there or saying the motor is likely to pop either way.
And definantly appriecate the advice and am taking it all on board.
If as you say your engine still has perfect compression ( i still think if you do a leakdown test you will find the 3 cyl of the blown turbo will have higher leakdown and some scoremarks in the bore), i wouldnt risk old ceramic turbos again. Next time you may not be so lucky .
If you want a turbo i have one, you can have it for $100, including actuator.
https://www.sau.com.au/forums/topic/119429-r32-gtr-turbos/#findComment-2220077
The 2 ceramic turbo's on the GTR do have a tendency to both go within a short time of each other. Id be terrorfied of fitting another ceramic turbo, only to have the other original go within a few 100 km's.
The stock ceramic turbo's are old and well behind the times now, save yourself more money down the track and invest in some aftermarket turbos now. Even N1's would be a great upgrade...
https://www.sau.com.au/forums/topic/119429-r32-gtr-turbos/#findComment-2220169
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
