  • Replies 94
Posted Images
can someone tell me the advantages and disadvantages and differences of the following pod filters cuz i dont no nothing about em, and plan to have one put in soon.
and also could someone tell me how does the diffrence in inches makes to the performence and sound.
thanks
Edited by anjoO
I've never seen #5 before, what is that? The Apexi one was rated the best out of HKS, Blitz and K&N in terms of filtration ability (overall power gain was just about the same across all 4), search for the thread and you should eventually find it. :D
welll thanks guys i think im defently going for the apexi pod.....but what about how ppl have 2 or 3 pods.....whats that all about (i guess for more air lol)....and how does one tell if one needs more then 1
how long do these things take to put in and get runnin......if all goes good ill get one tm haha
takes about 30mins to install
Twin Turbo = Twin Intake = Twin Pods
I think you'd need a full custom manifold to have twin pods on a single turbo or NA, you probably have to wire up another AFM too...
Not necessarily, you can have a pipe that splits into two, and run two pods off the one AFM.
Although, its entirely pointless, because the AFM will still be a bottleneck.
Could the AFM cope with having air pass through it at the higher airspeed created having twice the inlet size?
Why would it be at a higher air speed?
The turbo can only suck so much air in...
If there is twice the inlet size, its going to suck the same amount, it just wont be as dense.
all of those jap filters have really poor filtration which is why they have good airflow.
locally made unifilter pods filter much better but still flow well because they have a much larger surface area.
i think top racing sell apexi pm NIB on these forums he works there and should be able to help you out .
and yes go for Apexii have twin apexi pods on my gtr and they are real good (albeit filthy and need replacing)
sorry just realised your over east chec through all sau sponser sites that should be able to help you out
Yeah there was a trend somewhere on here that result from a test between the pod filters to see which ones was the best. I remenbered the apexi one came out on top then the blitz, K& N and then HKS.
Just get any pod filter they'll give you the loud induction sound that your after.
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
