Wrong!! In a number of ways. Twin pods are popular but on my RB25DETT in the track car I ran single AFM and single pod, however the stock GTR setup is single airbox and is good enough for my 260rwkw/0-100 in 4.02s.
I did realise that twin setups can be run off a single filter, but AnjoO was aksing about having multiple pods for a single setup - which IMO is pointless, the only real time when having multiple intakes would have a potential benefit is in a twin system.
  • Replies 94
Posted Images
If you want the loudest pod, the HKS one is the go.
I have one and the induction noise is huge - pity it's one of the worst filters! :D
But then again my pod is shielded so I'm not worried about that. Get a pod and you should always pair it with a box or shield.
i have a apexi pod on my r33 and to be honest after 8 months of driving the car im sick of the induction noise.i have brought a standed airbox and will be putting that on to see if that shuts it up some . the car came with the pod and i have brought the standed box since with a good pannel filter i dont expect to drop power just lose some of the noise i hope
cheers
Heres an idea,....
Get a microphone and mount it under your hood near the STANDARD EFFICIENT and LEGAL filter box
and amplify it through your stereo system so you can deafen yourself and impress all the 14 yo schoolboys waiting for the bus in your area.
SK I think your right!
Yeh well the pod selection is easy the next problem would be heatshielding. All good too put on a pod filter but if its sucking in hot air then can anyone say detonation!! especially on those lovely 40 degree plus australian summers.
man, get the apexi kit from greenline or nengun (check to see which is cheaper)
I got the twin pods on my gtr and they are loud enuff, and as you saw on the website test, the filter the best too.
steve
the noise on a twin setup on a rb26 is much quiter than a single pod on an rb25
PS, I put this thread up there in my Top 20 worst ever questions
LOL sk!
Anyway - I have a LOUD K&N pod filter. I hate it, its too loud.
Anyway I have a custom heatshield, it fits R33. If you want it offer me $50plus $10 postage
Reason for sale - I now have a proper CAI box, from Maxx.
I also have a standard R33 airbox (no snorkel) with brand new B&N panel filter for $100 plus post if anyone is intrested.
Brendan
Edited by Tangles
to make a pod legal (in qld anyway) all you need is a fixed mount for it, for example a bar than comes from the adapter plate to one of the stock airbox mounts.
i have a front mount and can't run the stock airbox as i can't use the snorkel, so the airbox just sucks hot air, but i have a cold ait feed to the pod from the front bar, up through the empty intercooler hole.
having the pod partioned is only good if you have a feed to it. if you just have it partitioned off with no air feed to it then you will lose power.
i plugged the recirulation hole in the stock bov and that cut down a slight bit of induction noise. if you want a pod with minimal noise go for a k&n with the power intake top (the flat top one). i have had one before on my 180sx and it made no induction noise, and i'm veen in a skyline that had one with no noise, but it did have a slight partition. i will have to ask him if he has nosie now that he has put a hks filter on to see if is just the partition.
Well it turns out it WASNT a direct bolt on and i neee some bs adapter now...mmmmmmmmmmm....maybe i bought the wrong pod?
heres the one i got can someone tell me if i got the right one.
Pod Filter
Edited by anjoO
Pod Filter
thats the one
it should bolt on
was it suppose to come with a adapter? cuz i was putting it on but none of the bolts lined up...it needs a adapter........and me being asian i tried putting it on every dodgy way i could think of....and it still didnt work......so u defiently know its not a direct bolt on hahhahahah
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
