Hey guys,
Just a quick question, will stock r34 gtr injectors fit and work perfectly in an r32 gtr? i have 1 injector leaking and was wondering if i could replace just 1 with a 34 or 33 injector, or maybe the whole 6 of them.
Thanks guys
no, 34 gtr injectors are not the same as 32 gtr injectors.
THEY ARE 10 YEARS YOUNGER!
HAHAHAH AHHAHAHA HAHHAHAHA OH I KILL ME!
anyway....they are identical, but its a good idea to get all your injectors cleaned and flow tested....then put the best flowing injectors in #6, then #5 etc
LOL thanks duncan! i figured mine looked older.
Cheers
On the topic of where to place the higher flowing injectors..
I remember some time ago some one did a flow test on the std rb25 inlet manifold, it showed the two middle cylinders flowed slightly greater, I believe it was on the SDU forums; would this not indicate that the higher flowing injectors should be placed in the two middle cylinders.
The GTR style plenum is a different story, I'm assuming this is where the front and rear cylinder = higher flowing injectors origionated from and applied to the rb25det style plenum? :(
A tuner i spoke to told me that cyl 1 and 6 are generally most starved of fuel on rb20s. Thus to put a fuel injectors that flows slightly more and will supply that little bit more to those cylinders was a good idea...
I myself can only go on what ive been told.
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
