Hey all.
Probably heard this before but the search tool is as useless as tits on a bull so i didn't bother.
I have this clicking noise behind the dash (S1 33) on start up.. sounds like a shaft popped out or something. Just wondering if anyone has come across this before and what they did to fix it! cos it sh!ts me to tears.
cheers
Evan
https://www.sau.com.au/forums/topic/119458-ac-problem/
Very common R33 problem. There are several threads on it. It is your heater unit which requires removing the entire dash (EVERYTHING) to fix.
Someone has written an EXCELLENT guide on how to do this, but you need to allow for a minimum of 4 hours to pull it apart. I guess you need 4 hours to put it back together.
And before you ask, no... it will do no harm to leave it like that. Mine does it and the heater flap still works fine. It's a sensor that has no contact anymore. The flap moves and should press two contacts together to indicate the end of the movement, but the contacts are dirty or broken, so it keeps trying to push further until it times out and stops. So it still functions correctly.
Mine will do the noise if I switch to "feet". Test it out and see if you get it then as well as startup.
https://www.sau.com.au/forums/topic/119458-ac-problem/#findComment-2202023
i dont think its a sensor, its the motor that opens and closes the flap (im not sure if thats what you meant randy).
i've got a pic of the gears inside the motor somewhere when i did it. one of the gears were completley chewed. i'll get a pic up tomorrow.
https://www.sau.com.au/forums/topic/119458-ac-problem/#findComment-2202726
Security: Not sure, just what I have read. Although the gear would be chewed from the constant clicking as the gear keeps trying to turn. I'm sure there must be some way for it to know when to stop moving?
So anyway, I just guessed that there would be a dead contact in my heater unit that wasn't telling the gears/motor when to stop turning.
Seems people replace their entire heater unit when this happens? I haven't seen or heard of anyone actually fixing it themselves without replacing the whole unit.
https://www.sau.com.au/forums/topic/119458-ac-problem/#findComment-2205855
The A/c in my car resets itself whenever yoiu turn the car off.... so it's always the same thing when you start up. or like was said earlier if you switch to feet. It is pretty annoying and i would llike it to go away!
As far as pulling the dash out.... that sucks. I'll have to get motivated and look for my self. (same old story, mechanics car is the last to get looked at!)
Cheers for the Info guys. now i know where to start looking!
-Evan
https://www.sau.com.au/forums/topic/119458-ac-problem/#findComment-2207536
I know i risk sounding like the biggest idiot for this, but does the heater work straight away on startup? Mine's made this clicking noise for ages, but when i finally needed the heater this morning it didn't blow heat until the engine warmed up, and i don't remember if it used to do that, it's been that long since i needed to use it.
https://www.sau.com.au/forums/topic/119458-ac-problem/#findComment-2245772
OK what i wanna know is, to get rid of this clickin noise we replace the whole heater core or fix the sensors or the flaps??
Lol anyone in sydney wanna help me over a weekend!!
But leaving it like this, will it wreck anything over time??
Edited by siddr20
https://www.sau.com.au/forums/topic/119458-ac-problem/#findComment-2245853
yeah i had this same problem it is one of the biggest pain in the ass jobs for such a little part to be replaced the part you need is like a little actuator thing with an arm on it and i think its the cogs inside it get stripped over time
Baron25 - Your heaters should work once your car is warmed up not straight away.
Here is a picture of the part that needs to be replaced to get rid of the clicking noise. It is the bit with the green square around it the bit with the yellow circle around it is the heater setup with the heater core in it. I bought the part (just the bit that clicks not the whole heater) of a person on hear for like $60 and the problem was solved. You will need to pull all the pillars, dash, everything in the dash, Centre consoles, stearing wheel and possibley the front seats out. Theres a guide on hear somewhere on how to pull the dash out which was extremely useful. Good luck with the job if you need any help at all give me a pm.
cheers iLEC
https://www.sau.com.au/forums/topic/119458-ac-problem/#findComment-2248839
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
