Is the variable valve timing something I can use? BTW this is the one and only engine I intend to build for a 240z, so if it takes years I don't mind. With that in mind I'm intending to really go town, and I'm an electronics fan, so was thinking MoTec make the best ECUs? Probably get one of those, if I could get one with a switchable map that'd be great, that way I could map it for 99RON fuel and for 109RON fuel, I guess?
Are the RB cranks interchangeable? Does anyone know for a book that lists the component specs please? I have an L series tuning book that tells me all the crank dimensions, strokes, different piston dimensions and chamber ccs so I can figure out the right combination of parts. I need something for the RB.
The only way to make high power with a NA engine is high RPM with high compression, get the air in so you can make it.
Yes it is revs that kill a motor, light weight pistons and rods do wonders.
Use the link in my sig to dload the rb30 pdf.
  • Replies 73
Posted Images
Thank you! I just skimmed the pdf and am now printing it for my perusal, brilliant ;)
http://www.automotiveforums.com/vbulletin/...d.php?p=4141983
That's another forum I've been chatting about this on. I wonder how you figure out your rev limit for an engine, or do use some informed guess work and hope for the best? I couldn't afford a destruction orientated development plan, and guess for the sake of not having to rebuild the engine regularly should err on the side of caution. If I could see 9500 rpm I'd be a happy chappy, apparently that's doable. 10k sounds better though, but probably both unrealistic, unless I can get some motorbike engine components into the equation.
Anyway will read the pdf, much appreciated.
It really is only an estimate as to where others have broken oil pumps etc..
My self... I won't be taking mine past 6500-7000rpm but don't need to as I run turbo. :kiss:
Bu5ter has the good bits, an ati balancer & full oil pump drive gear and takes his to 8500rpm.
I think realistically 8500rpm is pushing an RB to the very limit. Its proven even the ol' rb26 taking it regulary past 7000rpm drastically shortens its life (i.e bathurst)
Will an RB25/RB26 balancer fit the RB30 crank?
Does it make any difference to the harmonics problems over the standard 30 balancer?
The rb's are all the same, the only difference is the extra deck height, everything is the same as the rb20/25/26 block. :kiss:
So yes.. the balancers fit the standard rb30 crank.
Which is why I stated earlier, its been known for vlt's running around to break oil pump drive gears over 6500rpm, skylines, it appears to be some where over 7500rpm, when you look at any serious high rpm rb26 they too run aftermarket balancers so there is definitely something in it.
im using rb25de oil pump. it was even worse when i was running 10w60 oil. now im running 10w30 so its a little better. its not that helpfull that i do rev the car out often.. it just revs so damn quick that you dont realise..
im using a 25 harmonic ballancer. i had all of my interanls ballanced from the clutch, flywheel, crank, rods and harmonic balancer. its a very smooth reving engine. once i get my exhaust fixed i will try either get a video or a sound recording of it. i have been trying to for 6months. but havnt had the time. or been that happy with the sound of the exhuast...
if you aim of reving over 7000rpm you might have to look at injectors and you will need an aftermarket ecu. i still need to get one for mine as power starts dying away just before 7ish. so you will also need some high lift and duration cams to still be making power up there. you would also probly be wanting to look at hex throttles to help with the breathing.
I'm going for aftermarket throttle bodies, injectors, entirely new valvetrain, ecu etc. I don't care if I have to replace everything, so long as the engine is a Nissan straight 6.
I know the Mines skyline was good to 8500rpm plus, and I'll need the revs to make the power NA.
I really need lightweight and strong rods and crank, with everything perfectly balanced and forged pistons.
Edited by Russ_T
oh true. good luck man. ill be keen to see the results once its all done.
good on ya for building a high power NA. have you considerd the RB26 head much though? would save you a fair amount of $$ over time. and its easyer to make fit the block the a VVT head.
but yeah you will have a damn sexy sounding RB once its all done :D
One day I will put one of these into a 240/260Z
RB30 block and crank
3.1 litres
13.5 to 1 compression ratio
Polished combustion chambers
272 duration 10.8 mm lift cams
Titanium retainers
Tome valve springs, 55 lbs at the seat
2 mm oversize inlet valves
1 mm oversize exhaust valves
Ported RB26 cylinder head
Ported RB26 inlet, multiple throttle bodies and plenum
Tuned, coned collector extractors
4” titanium exhaust
JE forged pistons
Carrillo rods and rod bolts
ARP main bearing studs
ARP head studs
ACL race series bearings
N1 oil pump, with wide flange drive crank collar
RB26 water pump
Elf LM fuel
Motec ECU
Motec CDI
Mercury outboard coils
WoooHooo……400 bhp here we come….and wouldn’t it sound good
:D cheers :laugh:
BADR33: Thank you, I'll be sure to post my progress here (one day, buying a Z32 a the moment and finishing my other 240)
Sydney Kid: I love you, that is exactly what I need :) Sounds very much like what I imagined I'd need as well.
3.1 litres
Is that 3.1 overbored? How did you get that compression ratio? I imagined the RB26 head had one of the bigger chambers (low compression), are you thinking of welding up and reshaping the head chamber, or is that a tall piston (extra weight?) or longer rods (better idea, good stroke/rod ratio for high revs), or a domed piston?? What crank?
Thanks all. :D
MMMM VK56DE thats something i see in my fantasies....
Neways Naturally aspirated the only way to make power is REVS and lots of them, i was talking to Sydneykid quite some time ago about this and he said that the problem with high revving RB30's is they seem to get some wierd harmonics through which will eventually cause excesive wear on just about everything.... cant remember if he mentioned neways to eliminate this best u pm him i think, he's super friendly and like a nissan dictionary.
all six cylinder engines produce harmonics at revs.. they {and multiplr configs of 6 cyl..i.e. v12's} need a quality harmonic balancer to quench this.. 4 cyls and 8cyls dont even require a harmonic balancer if balanced correctly.. something to do with the 90degree firing cycle.
That's interesting.
One of these puppies then
http://www.atiperformanceproducts.com/prod...s/damnissan.htm
I'm running one of these on my RB28 - nice bit of kit but the 25% overdrive keeps shredding AC belts when I forget to turn off the AC switch (shouldn't be a problem for you 'tho).
  • 7 months later...
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
