I know theres been a thread about this somewhere but darned if i can find it - so im here to pester you all again.
Need some recommendations on a good suspension place in preferably Osborne Park that knows what they are doing with lowered R33's!
Wanna start ringing around today but need a starting point!
Thanks Lauren
https://www.sau.com.au/forums/topic/11953-suspension-recommendations/
Well don't quote me on this one and some of the other guys may be able to give better recommendations but when I was looking for suspension on my VL Turbo I went to W.A Suspensions in Osbourne Park.... They seemed to know what they were talking about and had a wide variety of cars in the workshop at the time... From your family car, to supra's and such , to a dragster and even a cop car...
Don't know how they rate in pricing our the brands they stock these days though...
Brett
Hey Niz,
Wa suspension is doing my suspension as we speak, a good friend of mine Rob works there and he has been so helpful so they definately deserve a fre plug, oh and also C-red came to the rescue aswell! thanks Jash!
C-red is a bit out of the ossie park area but i do recall Jash saying he can get some sweet coilovers, i have borrowed some nice HKS coilovers at the moment from him, maybe give him a buzz and see how much he will sell a set of em to ya for, do ya puupy eyes thing Niz, Jash will love it I am sure....:uh-huh: :bahaha:
I did a lot of calling around when it came time to fitting my koni shocks to my s14.
Most expensive was WA suspensions be far - they were double the price of anyone else...I am not exaggerating either.
Wilkinsons and C-red were the same price, actually, I think C-red were a little cheaper. I ended up getting C-Red to fit the gear and I am happy with the job they did. If I was getting an alignment done, I would probably go to Wilkinsons.
Wheelsworld are good too I have heard, John always has time to sit down and explain everything about what you need to you in very plain terms.
Originally posted by Nizmo
heard wilkinson were good also heard they were expensive. Anyway thanks for giving me a starting point :P
Wilkinsons are very good...the best IMHO.
Don't know where you heard they were expensive as that definitely is not the case.
Peter knows what works and what doesn't and will not sell you something you don't need unless of course you want it.
For example he did some minor tweeks to my Rex and it placed 12th outright at MC motorsport...only hi po cars on "race rubber" beat me so he knows his stuff.
Cheers
Chris
Originally posted by Kichigai
Precise Suspensions & Automotive are in Wangara and I think they do some of the import shops in that area so they may be another alternative.
Hmmm these guys arent bad.... The dealer I bought my R33 from uses them and I have had my car serviced there a couple of times... never used them for suspension work though...
Wangaras a little for. Want somewhere i can drop it off catch a taxi to work and not have it cost me a fortune. But bayswaters good i might get my folks to drop it off - its near them.
need suspension done haha but will need wheel alignment after Jash probably get it all done at the one place. Hows your suspension stocks looking at the moment?
Wilkinsons Bilensteins are 2 1/2 weeks away which if im going to MC's with some of the boys are not close enough so I'll try WA Suspensions.
    • I mean this in no disrespect to u mate; Are there clear tagged examples/explanations in our SAU forum for example, in my interest, this is how to do R34 Gtt suspension the right way? U guys did so much taking risks with experimentation that deserves recognition and those results helps us morons take the RIGHT path to buy quality / buy once. 🍻
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
