hey guys im currently chasing a injector resistor pack for a rb26, but its proving difficult to find one. so im thinking do any other model skylines, or nissans use the same resistor pack????
or if anyone knows anyone with one for sale let me know plz :P
also i need the detonation sensor plugs section of the main engine harness because i got sold a harness without this bit, if anyone has one lying around.
thanks
Brad
https://www.sau.com.au/forums/topic/119532-rb26-injector-resistor-pack/
A new resistor pack is about $150 from Nissan.
There's only one car I've found that uses the same resistor pack and that's the Cima from about 1989 using the VG30DET. Of course finding one of those is even harder.
The good news is that R30 Skylines and 280ZX had a resistor pack that can be adapted for the purpose. The connector is different, but if you can find a wreck with a complete loom, you can get both halves of the connector and adapt it to to the RB26 loom. The best places to get things like this are self serve wreckers.
If you get stuck I have a spare R30 pack with connector.
Hi, you can also simply buy 6 X 10 ohm resisters from JayCar or Dick Smith. Then wire them in series, one for each injector. You can do that as a pack, with the 6 resistors all shrink wrapped together, or one located at each injector.
:P cheers :D
so basically something like this wired in between the injector and main wiring harness with work with no problems at all and for the minimal cost? id imagine they would need to be well heat wrapped though. does the wattage matter at all?
http://www.dse.com.au/cgi-bin/dse.storefro...duct/View/R1626
seems rediculous that nissan sells them for 150 (in nz its around 250) considering the cost
Edited by SirRacer
Yep I run the R30 resistor pack.
Its very closely rated to that of the GTR resistor pack, from memory the GTR resistor pack measures up at 5.8ohms vs the R30 pack at 6.3ohms. The connector the resistor pack uses is the usual motormates/sprint auto shop type that sell for around $3.95. So there is absolutely no need to grab part of the loom, simply grab an Navara 8pin plug from your local auto shop and use one half of it.
I looked in to running cheap dicksmith/jaycar inline resistors but was put off after doing the watt calculations.
One won't see any problems running the cheap 5w resistors running around the street but if it hits the track or sustains high rpm for long periods of time... well.. I wouldn't risk it.
I then looked in to the 15-17w resistors and discovered they are mighty expensive. The rotor boys also have been known to make their own resistor packs and they most definitely do not use the cheap resistors, they use the 15-17w items, for six of these suckers you are look at slightly over $100. The rotor boys use 6.5ohms resistors, not 10ohms as the calcs would suggest. Interesting, ecu's have head room. >_<
$150 for a bran new resistor pack from nissan?
They are generally $100-$150 second hand at the wreckers.
And a few pics for those interested what the R30 resistor pack and plug looks like.
I grabbed part of the loom before I discovered the local autoshops sell the exact same plug. :nyaanyaa:
  • 1 month later...
I then looked in to the 15-17w resistors and discovered they are mighty expensive. The rotor boys also have been known to make their own resistor packs and they most definitely do not use the cheap resistors, they use the 15-17w items, for six of these suckers you are look at slightly over $100. The rotor boys use 6.5ohms resistors, not 10ohms as the calcs would suggest. Interesting, ecu's have head room. :)
I grabbed part of the loom before I discovered the local autoshops sell the exact same plug. :D
what is the main issue cubes. is it simply the resistor being affected by heat??
sydneykid is pretty spot on, so sydneykd would you mind explaining cubes' theory and your opinion of it.
will the computer also be affected by the different ohms?
Do some googling and read up on the theory behind it your self, much more rewarding. :D
Yes Roy is on the ball... Just get the correct items from the word go.
By the time you by a set of gtr injectors then have them cleaned... Your only a few hundred off a set of nice shinny new items from nengun.
EDIT: Ok I've done a quick google. Explains all you need to know.
Scroll to just past half way.
http://www.megamanual.com/v22manual/minj.htm
For your own curiosity type in the gtr injector specs... And take very close note of what ohm resistors they recommend you use.... Nissan got it spot on from factory, well close enough. :(
Which is why you don't use 10ohm resistors; its not as simple as high imp resistance - low imp resistance = the resistors to use.
Don't stuff around, use what or damn close to what Nissan use, they are not silly people they know what they are doing, stick to the ~5.8 resistors, 6.3ohms from the r30 is bugger all and works perfectly fine on mine and many others.
If Nissan thought it was sufficient to use crappy little 10w resistors I'm damn sure they would have done so instead of using the bulky big arsed resistors they do.
Do some googling and read up on the theory behind it your self, much more rewarding. :blush:
For your own curiosity type in the gtr injector specs... And take very close note of what ohm resistors they recommend you use.... Nissan got it spot on from factory, well close enough. :yes:
cheers, i got my 700cc injectors for 600 so i think a resistor pack is definitley worth the trouble :angry:
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
